Click Here to report links gone
Fresh install of V4 and i have no links for users to report SPAM anymore, can anyone help
TIA
TIA
Re: Click Here to report links gone
I am working on rebuilding this feature using PHP. Stay tuned! (This one is high on the list)
Much appreciated!
Hi there
Any progress?
Any progress?
Finally upgraded to v4 and just noticed this as well.
Wondering if I've missed something or this is still in the works.
Any updated information would be greatly appreciated.
Any update on this?
Still in the works. The releasing part is done, just need to finish the reporting part.
can I do anything to accelerate this a litte bit?
We are still running on v3 because of this feature and now with the turn of the year let's encrypt isn't working anymore.
So we have to migrate to v4 within the next 2 months ...
Sincerely,
Ulrich.
Sincerely,
Ulrich.
Sure can. I'll bump this to the top of my list.
Hello shawn,
many thanks!!!!
I made a donation too, hope this also helps
Sincerely,
Ulrich.
many thanks!!!!
Sincerely,
Ulrich.
Thank you so much!freyuh wrote: 18 Jan 2022 15:58 Hello shawn,
many thanks!!!!
Sincerely,
Ulrich.
Report link is back in 4.0.4-32:
You will find the configuration options under 8) Spam Settings in eFa-Configure.
Options to control the report link:
1) Non Spam Settings
8) Trusted Networks
9) Inline Signature Rules
8) Trusted Networks
Thank you very much Shawn
/var/eFa/lib/eFa-Configure/func_asknonspam: touch /etc/MailScanner/rules/inline.sig.txt.rules
I think this should be /etc/MailScanner/rules/inline.sig.text.rules
Thanks, I'll get this corrected.
Shawn, I have enabled inline signature but mailscanner isn't inserting the signature. Any ideas?
Have you edited the inline sig rules?
When I added mydomain.com, it inserted rules into these files.
sudo grep mydomain.com /etc/MailScanner/rules/*
/etc/MailScanner/rules/inline.sig.html.rules:To: *@mydomain.com /etc/MailScanner/reports/en/inline.sig.html
/etc/MailScanner/rules/inline.sig.text.rules:To: *@mydomain.com /etc/MailScanner/reports/en/inline.sig.txt
Both includes exist and contain a signature.
It appears it should be working. When it appends the inline sig is it logged someplace? I didn't find anything obvious.
After I Enabled it under option 1) Non Spam Settings I have it appending to ALL domains. Not just the domains appearing in the rules.
Mailscanner.conf shows it's using custom(nonspam) as the spam action:
Sign Clean Messages = No
It's acting as if Sign Clean Messages = Yes yet I have confirmed it is No. It appears custom(nonspam) is the issue. Rebooting the server doesn't correct the issue.
Any ideas?
Any ideas?
I have to take a look at it ...
I think the evaluation of the rules is missing in the custom function.
The logic for that has to be implemented ...
custom(nonspam) overrides the Sign Clean Messages to add extra variables.
Do you have the following in MailScanner.conf
Inline HTML Signature = %rules-dir%/inline.sig.html.rules
Inline Text Signature = %rules-dir%/inline.sig.text.rules
Yes I (we) have.
But the signature is nevertheless attached to the email.
And you have a small error in the file CustomAction.pm:
should be
} elsif ($file =~ /inline.sig.in.txt/ && $spamwhitelisted eq "1") {
} elsif ($file =~ /inline.sig.txt/ && $spamwhitelisted eq "1") {
And I recognize this, because the english report is attached instead of the configured german ...But the signature is nevertheless attached to the email.
