Msmilter Message in var/log/messages
msmilter-init: /usr/lib/MailScanner/init/msmilter-init: line 68: MilterPIDFile: command not found
Solution: Added the QUICKPEEK variable and value
/usr/lib/MailScanner/init/msmilter-initCode: Select all
PATH=$PATH:/usr/sbin:/usr/bin:/bin:/sbin
export PATH
NAME=MSMilter
DAEMON=/usr/sbin/MSMilter
QUICKPEEK=/usr/sbin/ms-peek
ms_conf=/etc/MailScanner/MailScanner.confCode: Select all
systemctl daemon-reload
