root password
rooter_c
root password
Post by rooter_c »
Don't know if I'm doing something wrong, but I have followed the Migration Guide steps twice now, and something is resetting my root password after I copy the backup files across, then run through the eFa-Init wizard. Having to do a Centos root password recovery to progress.
rooter_c
Re: root password
Post by rooter_c »
I'm also getting these errors and no mail delivery. I'm not using DMARC or DKIM
Nov 15 10:36:22 eFa4 postfix/cleanup[3612]: warning: connect to Milter service inet:localhost:8891: Connection refused
Nov 15 10:36:22 eFa4 postfix/cleanup[3612]: 47DdCp6kn7zCLsT: milter-reject: CONNECT from localhost[127.0.0.1]: 4.7.1 Service unavailable - try again later; from=<root@towong.local>
Re: root password
root password is locked down by design. You can of course sudo in and change that if you desire.
Not sure why you have that milter, but edit /etc/postfix/main.cf and remove the milter inet:localhost:8891 and reload postfix. If you are not using DKIM, you don't need it.
rooter_c
Re: root password
Post by rooter_c »
Thanks, as suggested removed milter references to ports 8891 (and 8893) in main.cf, they don't seem to be getting removed when disabling dkim / dmarc as earlier suggested by tesme33
webguyz
Re: root password
Post by webguyz »
shawniverson wrote: 15 Nov 2019 05:57 root password is locked down by design. You can of course sudo in and change that if you desire.
How can I allow root password and access from outside using tools like WinSCP or Putty.
Re: root password
<post removed>
Lapse in judgement detected.
Re: root password
I strongly suggest that you use ssh keys to allow access to your root account rather than setting a password.
It'll also make the winscp and putty tools easier to use.
Personally, I use a non admin account as my login using ssh keys, and then taking the second step of using sudo to make any changes that require root permissions.
jamerson
Re: root password
Post by jamerson »
pdwalker wrote: 15 Apr 2020 07:03 I strongly suggest that you use ssh keys to allow access to your root account rather than setting a password.
this is really handy, is there some kind of tutorial to get the privat key set up?
Re: root password
I am sure there are many tutorials online for doing this.
Do you need one for winscp and putty?
jamerson
Re: root password
Post by jamerson »
pdwalker wrote: 05 Jan 2021 07:47 I am sure there are many tutorials online for doing this.
Thank you my friend,
ive got it set up already.
