clamd@scan.service start operation timed out. Terminating
Posted: 12 Nov 2019 13:10
by doggy101
after upgrading to Stable 4.0 EFA the Spamfilter stopped working and messages are piling up.
The start-up result is done.
Nov 12 13:57:02 EFAmailscanner CROND[14028]: (root) CMD (/usr/sbin/eFa-Monitor-cron >/dev/null 2>&1)
Nov 12 13:57:02 EFAmailscanner CROND[14029]: (root) CMD (/usr/sbin/checkreboot.sh)
Nov 12 13:57:30 EFAmailscanner MailScanner[14406]: Cannot find Socket (/var/run/clamd.socket/clamd.sock) Exiting!
Nov 12 13:57:30 EFAmailscanner MailScanner[4734]: Virus Scanning: No virus scanners worked, so message batch will be tried again
Nov 12 13:57:58 EFAmailscanner systemd[1]:
clamd@scan.service start operation timed out. Terminating.
Nov 12 13:57:58 EFAmailscanner systemd[1]: Failed to start Generic clamav scanner daemon.
-- Subject: Unit
clamd@scan.service has failed
is the something changed in permissions ?
found an article which stated that the issue is caused by
/run/clamd.scan 0710 clamscan virusgroup permission, I adjusted it to clamscan:clamscan but that did not work
Any sugestions?
Re: clamd@scan.service start operation timed out. Terminating
Posted: 12 Nov 2019 13:57
Can you check the override file located here?
/etc/systemd/system/clamd@scan.service.d/override.conf
It should be set at 300. Try increasing it to 600 and report back please.
Posted: 12 Nov 2019 16:10
by doggy101
it's allready on 900
Posted: 12 Nov 2019 16:12
by doggy101
and cpu is going through the roof
clamscan 87.2 % /usr/sbin/clamd -c /etc/clamd.d/scan.conf
Posted: 12 Nov 2019 16:45
It will until signatures are loaded into memory.
How many CPUs do you have?
Posted: 12 Nov 2019 16:48
doggy101 wrote: 12 Nov 2019 16:10
Increase it to 1200 and report back. For some reason your machine is taking an extraordinary amount of time to load all the signatures.
Also check and make sure you have at least 2 CPUs and 8GB of memory.
Posted: 12 Nov 2019 18:31
by doggy101
changed to 2CPU and 8GB, struggling with root access to get the value of 900 adjusted,
cpu and memory boost did not solve the issue
Nov 12 19:22:23 EFAmailscanner MailScanner[5935]: Cannot find Socket (/var/run/clamd.socket/clamd.sock) Exiting!
Nov 12 19:22:23 EFAmailscanner MailScanner[3950]: Virus Scanning: No virus scanners worked, so message batch will be tried again
Nov 12 19:22:34 EFAmailscanner systemd[1]:
Nov 12 19:22:34 EFAmailscanner systemd[1]: Failed to start Generic clamav scanner daemon.
-- Subject: Unit
-- Defined-By: systemd
-- Support:
http://lists.freedesktop.org/mailman/li ... temd-devel
-- Unit
clamd@scan.service has failed.
-- The result is failed.
Nov 12 19:22:34 EFAmailscanner systemd[1]: Unit
clamd@scan.service entered failed state.
clamd@scan.service failed.
Posted: 12 Nov 2019 18:52
by doggy101
changing to 1200 did not solve the issue..
anything else to look for?
Nov 12 19:50:35 EFAmailscanner systemd[1]:
Nov 12 19:50:35 EFAmailscanner systemd[1]: Failed to start Generic clamav scanner daemon.
-- Subject: Unit
-- Support:
-- Unit
Nov 12 19:50:35 EFAmailscanner systemd[1]: Unit
Posted: 12 Nov 2019 19:16
by doggy101
Posted: 13 Nov 2019 07:01
No, systemd is terminating clamd due to timeout. So we can assume it is stalling. This is not a socket problem. You never reach socket initialization phase.
We can verify the socket as follows:
/etc/tmpfiles.d/clamd.socket.conf:
d /var/run/clamd.socket 0750 clamscan mtagroup -
/etc/clamd.d/scan.conf:
LocalSocket /var/run/clamd.socket/clamd.sock
ll -Z /var/run/
drwxr-x---. clamscan mtagroup system_u:object_r:antivirus_var_run_t:s0 clamd.socket
If the above checks out I want you to disable clamav-unofficial-sigs as follows:
sudo sed -i "/^user_configuration_complete=/ c\user_configuration_complete=no" /etc/clamav-unofficial-sigs/user.conf
sudo rm -rf /var/lib/clamav/*
sudo freshclam
sudo systemctl start clamd@scan
Report back whether clamd starts after relieving it of the extra signatures...
Posted: 13 Nov 2019 17:09
by doggy101
On:
ll -Z /var/run
I got:
[root@EFAmailscanner ~]# ll -Z /var/run
lrwxrwxrwx. root root system_u:object_r:var_run_t:s0 /var/run -> ../run
so it didn't check out
Posted: 13 Nov 2019 17:20
Posted: 13 Nov 2019 19:03
by doggy101
[root@EFAmailscanner ~]# ll -Z /var/run/
-rw-r--r--. root root system_u:object_r:auditd_var_run_t:s0 auditd.pid
drwxr-x---. chrony chrony system_u:object_r:chronyd_var_run_t:s0 chrony
drwx--x---. clamscan clamscan system_u:object_r:antivirus_var_run_t:s0 clamd.s can
drwxr-x---. clamscan mtagroup system_u:object_r:antivirus_var_run_t:s0 clamd.s ocket
Posted: 13 Nov 2019 19:36
by doggy101
thanks all is fine again
much appreciated ....
