Cant log in to console?
Posted: 25 Jun 2013 13:32
by Blackbird
I have fired up efa 0.3
I cannot log into the console with root/password as it states.
What is the trick?
So far thats all I get, machine boots, sits at login prompt, I can get no further.
TIA
Re: Cant log in to console?
Posted: 25 Jun 2013 17:58
by darky83
Is it an already configured system or an new image?
For a new vm deployed install the combination: root/password should work.
if that does not work try: efaadmin/password
On a blank image these should work just fine.
Also try typing the password as username does it look ok there?
Posted: 25 Jun 2013 22:20
by Blackbird
this is the vm appliance freshly downloaded and imported.
trying your suggestions now.
Posted: 25 Jun 2013 22:26
by Blackbird
efadmin/password got me in.
what do I run to kick off the configuration?
from reading it sounded like it should have happened automatically but I am not seeing that.
now logged into the VM with an account with no rights to even do ifconfig so a bit stuck at this point.
thanks!
Posted: 25 Jun 2013 22:31
by Blackbird
please disregard.
vm is now acting as it should.
maybe something went wrong the first time, but deleted and re-imported and things are looking on the up and up.
