Header information - missing
Rod-IT
Post by Rod-IT »
Hi all,
I searched but didnt find anything that matched.
As of about the last month, the EFA I use at home seems to have lost the ability to show me header information - when I click the "I" icon, I get only
received by
received on
received from
none of the header information shows any more and it doesn't matter how I try to show this.
Pointers on where to look?
EFA has been restarted as have the services, no dice.
Re: Header information - missing
Sounds like the GeoIP database problem.
Search the forums for recent posts on GeoIP and make sure your GeoIP data files are correct. (sorry, just driving by, no time to search for it myself)
Rod-IT
Post by Rod-IT »
Thank you for the reply - for some reason I was not notified you responded.
I found a fix and will await V4, would never have guessed that had any relation, if anything I would expect the headers to still show, just fail on the lookups.
Oh well, but thanks.
How do I mark this as solved / give you credit for your help?
Just as you did. All good.
