V4: 161 MB free memory
Posted: 21 Oct 2019 12:32
To speedup booting and get some extra memory I disabled kdump.(as kernel Crashes are really rare these days)
Check boot duration time
46.423s kdump.service
32.758s clamd@scan.service
6.156s tuned.service
4.936s mailscanner.service
4.822s mariadb.service
4.670s postfix.service
3.482s network.service
3.404s dev-mapper-vg_00\x2dlv_root.device
3.397s systemd-udev-settle.service
Check dmesg message
[ 0.000000] Reserving 161MB of memory at 688MB for crashkernel (System RAM: 4095MB)
Check status kdump
● kdump.service - Crash recovery kernel arming
Loaded: loaded (/usr/lib/systemd/system/kdump.service; enabled; vendor preset: enabled)
Active: active (exited) since Thu 2019-01-24 22:02:47 CET; 1h 45min ago
Process: 5406 ExecStart=/usr/bin/kdumpctl start (code=exited, status=0/SUCCESS)
Main PID: 5406 (code=exited, status=0/SUCCESS)
CGroup: /system.slice/kdump.service
Check memory
Stop and disable kdump
Removed symlink /etc/systemd/system/multi-user.target.wants/kdump.service.
Change crashkernel -> no
Rebuild
Check new memory
systemd-analyze blame32.758s clamd@scan.service
Check dmesg message
dmesg | grep ReservingCheck status kdump
systemctl status kdumpLoaded: loaded (/usr/lib/systemd/system/kdump.service; enabled; vendor preset: enabled)
Check memory
free -mCode: Select all
systemctl stop kdump
systemctl disable kdumpChange crashkernel -> no
sed -i 's/crashkernel=auto/crashkernel=no/' /etc/default/grubCode: Select all
grub2-mkconfig -o /boot/grub2/grub.cfgCode: Select all
rebootCode: Select all
free -m
