How to change Date format to mm/dd/yyyy
webguyz
Post by webguyz »
Right now the system shows dd/mm/yyyy
Is this a Centos thing or is there something in a config file?
Re: How to change Date format to mm/dd/yyyy
Take a peek in /var/www/html/MailScanner/conf.php
webguyz
Post by webguyz »
Thanks for the hint!
And thank you for this project. We appreciate all you do!
