EFA Upgrade 3.0.2.5 to 3.0.2.6 Breaks Things
Posted: 30 Sep 2019 07:01
by barbours
HI All,
I am fairly new to EFA, and need a little bit of help. I have 3.0.2.5 up and running on a vmware appliance of centos. I downloaded it from the EFA site. With the 3.0.2.5 version things run fine and I am able to pass mail from the sender to through appliance and into my mail server. During the install I selected Auto Update option #7. After the updates are completed, mail will no longer leave the queue and get delivered to the mail server. It sits in the outbound queue on EFA. If I roll the vm back using the snapshot function in vmware (rolling back to 3.0.2.5) and resend test mail, things work as expected.
I am not sure where to start looking for the thing that is breaking the passing of scanned email from the EFA server to my internal mail server.
Any assistance is greatly appreciated. sb
Re: EFA Upgrade 3.0.2.5 to 3.0.2.6 Breaks Things
Posted: 02 Oct 2019 04:09
by barbours
Figured this one out using the solution provided by shawniverson. Found his solution on this post:
viewtopic.php?f=5&t=3128&p=14668#p14668
Essentially, do the following after upgrade
rm /var/lib/clamav/*yar
rm /var/lib/clamav/*yara
service clamd start
Thanks again Shawniverson
