HowTo show RBL rejected inbound mails in eFA web interface
viorelfmt
Post by viorelfmt » 20 Sep 2019 12:55
Hello all,
I'm new here, this is my first question here :mrgreen:
I'm using eFa v4 for incoming mails of multiple domains. All seems good but lately i'm strugling with an wish/issue.
I want all the rejected e-mails for rbl causes to be displayed in web interface. I don't know if its available in eFA and not enabled my me or not available at all for now.
Right now, as in every postfix, I see a message like this in /var/log/maillog:
Sep 20 14:47:07 efa4 postfix/smtpd[21229]: NOQUEUE: reject: RCPT from mailsender.com[1.1.1.1: 554 5.7.1 Service unavailable; Client host [1.1.1.1] blocked using dnsbl-1.uceprotect.net; IP 1.1.1.1 is UCEPROTECT-Level 1 listed. See http://www.uceprotect.net/rblcheck.php?ipr=1.1.1.1; from=<sender@mailsender.com> to=<mail.receiver@receiver.com> proto=ESMTP helo=<mailsender.com>
If I can tweak somehow the eFa config to redirect the output of /var/log/maillog and parse in web interface would be great and of use to a lot of us :).
Thanks,
Have a good day.
fvbrasileiro
Re: HowTo show RBL rejected inbound mails in eFA web interface
Post by fvbrasileiro » 24 Sep 2019 14:15
Hello Viorelfmt,
You have to remove reject_rbl_client on postfix and enable then in spamassassin. On your local.cf you can use:
RCVD_IN_RP_RNBL
RCVD_IN_BRBL_LASTEXT
RCVD_IN_PSBL
RCVD_IN_BL_SPAMCOP_NET
RCVD_IN_SBL
RCVD_IN_SORBS_HTTP
RCVD_IN_SORBS_SOCKS
RCVD_IN_SORBS_WEB
RCVD_IN_XBL
RCVD_IN_PBL
Like this:
header          RBL_BARRACURA eval:check_rbl('BARRACUDA','b.barracudacentral.org')
describe        RBL_BARRACURA Listed in b.barracudacentral.org
score           RBL_BARRACURA 5.0
header          RBL_SURRIEL eval:check_rbl('SURRIEL-PSBL','psbl.surriel.com')
describe        RBL_SURRIEL Listed in psbl.surriel.com
score           RBL_SURRIEL 5.0
header         UCE_PFSM_1 eval:check_rbl('UCEPROTECT','dnsbl-1.uceprotect.net')
describe       UCE_PFSM_1 Listed in dnsbl-1.uceprotect.net
score          UCE_PFSM_1 3.0
kalessin
Post by kalessin » 17 Nov 2020 18:16
what's the difference with the described at viewtopic.php?f=19&t=3393 ?
