Are baruwa reports complete?
Posted: 06 May 2013 04:06
by DavidRa
I'm not sure if this is expected - but I'm almost certainly seeing incomplete or partial daily spam reports from baruwa. In case it's not clear I mean the reports with subject "Baruwa quarantine report for ..."
I'm almost 100% sure I get hundreds or thousands of spams a day (thirty or so mailboxes, many with well published addresses that are over a decade old). Yet every single baruwa daily report contains exactly 25 messages. Am I missing some configuration parameter to change the report size? Is there a missing link to the full list?
Re: Are baruwa reports complete?
Posted: 06 May 2013 07:04
by darky83
That should be allot more, my reports show hundreds ~ thousands of messages.
I have never seen any config variable for this in baruwa.
I will browse around in the mysql DB maybe there is some kind of option there.
Posted: 06 May 2013 10:40
by DavidRa
How intriguing. Perhaps then it's config or status.
I imagine it's highly likely to be at least slightly misconfigured. Indeed - I just realised that dccifd has never been able to communicate with the world (port 6277 UDP). Maybe I should go back and check all the config too.
Edit: Ah, lots of missing outbound firewall ports now fixed ... but something perhaps is not quite right - the server cannot be "initialized" (Servers -> Scanners; stuck in the Initialize state, clicking the Initialize button does nothing). Could be false alarm, may not be, the status for the server is green at top of page.
Posted: 06 May 2013 11:26
by darky83
That is ok, the servers -> Scanners is an unused page in baruwa 1.x :)
(http://lists.baruwa.org/pipermail/baruw ... 01788.html)
