Efa4 timeout issues solution
Posted: 23 Aug 2019 18:01
Testing the latest Efa4 version results in 2 minor issues
The issue is created by rpmbuild/SOURCES/eFa-4.0.0/updates/update-4.0.0.sh due a wrong section name. ( commit-id 6dd91d0)
Errors in var/log/messages:
1. /etc/systemd/system/mariadb.service.d/override.conf:1] Unknown section 'System'. Ignoring.
2. ]systemd[1]: [/etc/systemd/system/clamd@scan.service.d/override.conf:1] Unknown section 'System'. Ignoring.
This can be fixed by changing lines 513 and 523 from [System] -> [Service]
Temp solution
1.
Reload deamon / Restart and Check
2.
Reload deamon en restart
And a different error for msmilter
3. Message in var/log/messages
msmilter-init: /usr/lib/MailScanner/init/msmilter-init: line 68: MilterPIDFile: command not found
Solution: Added the QUICKPEEK varible and value
Temp solution
1.
/etc/systemd/system/mariadb.service.d/override.confCode: Select all
[Service]
TimeoutSec=900Code: Select all
systemctl daemon-reload
systemctl stop mariadb
systemctl start mariadb
systemctl status mariadbCode: Select all
/etc/systemd/system/clamd@scan.service.d/override.confCode: Select all
[Service]
systemctl daemon-reloadAnd a different error for msmilter
/usr/lib/MailScanner/init/msmilter-initCode: Select all
PATH=$PATH:/usr/sbin:/usr/bin:/bin:/sbin
export PATH
NAME=MSMilter
DAEMON=/usr/sbin/MSMilter
QUICKPEEK=/usr/sbin/ms-peek
ms_conf=/etc/MailScanner/MailScanner.confCode: Select all
