Sophos does not Block Malware Detection Mail will be sent
benscha
Post by benscha »
Hi Guys
i got the following issue. Sophos is installed on my EFA. Sophos will detect the Malware and a E-Mail will be sent:
Subject: [SAV-LINUX] Threat 'Troj/RtfExp-EP' detected on efa.domain.local
A threat classified as 'Troj/RtfExp-EP' was detected in the file '/var/spool/MailScanner/incoming/SpamAssassin-Temp/.spamassassin14362Leu17Ktmp' when attempting to open it at Wed Aug  7 14:57:15 2019 CEST +0300 (2019-08-07 14:57:15 UTC).  Access to the infected file was not allowed.
From my Mailscanner.conf
Quarantine Infections = yes
Virus Scanners = sophos clamd
i have allready tried the following steps with no success:
http://lists.mailscanner.info/pipermail ... 01114.html
What makes me a bit confused is the Text "Access to the infected file was not allowed" in the Mail. Are there any Permission issues?
the Process savd is running as root
root      1706  0.0  0.0 592512  6228 ?        Sl   Jul22   0:52 savd etc/savd.cfg
does anyone of you guys has a solution for me?
always happy for any hints and tipps! :clap: | EFA 3.0.2.6
Re: Sophos does not Block Malware Detection Mail will be sent
You are running sophos as a daemon, so MailScanner is oblivious. Sophos sees the threat via the daemon. MailScanner should call out to sophos for a scan during mime parsing. Verify your path to sophos in the following file.
/etc/MailScanner/virus.scanners.conf
sophos			/usr/lib/MailScanner/wrapper/sophos-wrapper			/opt/sophos-av
benscha
Post by benscha »
Hi shawniverson
thx for your reply.
the path in /etc/MailScanner/virus.scanners.conf is correct.
should i disable sophos daemon?
thx!
