eFa server failing PCI Compliance scan
cphillips
Post by cphillips » 10 Jul 2019 09:20
I run an eFa 3.0.2.6 server and it is scanned quarterly for compliance as we take credit card payments.
The latest scan has failed with the following:
Banner Based Vulnerabilities for Postfix smtpd
CVEs:
CVE-2009-2939 6.9 AV:L/AC:M/Au:N/C:C/I:C/A:C
CVE-2008-4977 6.9 AV:L/AC:M/Au:N/C:C/I:C/A:C
CVE-2011-0411 6.8 AV:N/AC:M/Au:N/C:P/I:P/A:P
CVE-2011-1720 6.8 AV:N/AC:M/Au:N/C:P/I:P/A:P
CVE-2012-0811 6.5 AV:N/AC:L/Au:S/C:P/I:P/A:P
CVE-2008-2936 6.2 AV:L/AC:H/Au:N/C:C/I:C/A:C
CVE-2017-10140 4. 6AV:L/AC:L/Au:N/C:P/I:P/A:P
CVE-2008-3889 2.1 AV:L/AC:L/Au:N/C:N/I:N/A:P
CVE-2008-2937 1.9 AV:L/AC:M/Au:N/C:P/I:N/A:N
It seems this is running Postfix 3.1.4 which is fairly old. Is it possible to update the version of Postfix on this system or am I better off migrating to eFa v4?
Thanks in advance.
Re: eFa server failing PCI Compliance scan
Post by shawniverson » 10 Jul 2019 10:18
Plan on moving to v4. :dance:
cphillips
Post by cphillips » 14 Jul 2019 08:38
Ok, I've now built an eFa 4.0 VM and still having the same issue, I also had security warning, TLS 1.0 enabled etc. I've sorted those out but still need to remedy the following:
CVE Score Vector
CVE-2017-10140 4.6 AV:L/AC:L/Au:N/C:P/I:P/A:P
They are coming up under a Security Metrics scan, under the heading "Banner Based Vulnerabilities for Postfix smtpd"
Thanks in advance
Post by shawniverson » 14 Jul 2019 14:10
Many of these look like false positives based on the smtpd banner (?) and postfix has long since fixed these issues.
For example...
CVE-2009-2939 says that postfix has write access to pids in /var/spool/postfix/pid, but this is not the case.
-rw-------. 1 root root  0 Jan 19 22:05 inet.smtp
-rw-------. 1 root root  0 Jan 20 19:34 inet.submission
-rw-------. 1 root root 33 Jul 14 00:37 master.pid
-rw-------. 1 root root  0 Jun 27 23:10 unix.bounce
-rw-------. 1 root root  0 Jan 19 22:10 unix.cleanup
-rw-------. 1 root root  0 Jan 19 22:10 unix.defer
-rw-------. 1 root root  0 Jan 19 22:10 unix.flush
-rw-------. 1 root root  0 Jan 22 21:46 unix.local
-rw-------. 1 root root  0 Jan 19 22:13 unix.retry
-rw-------. 1 root root  0 Jan 19 22:05 unix.showq
-rw-------. 1 root root  0 Jan 19 22:10 unix.smtp
You can clearly see that only root has access, and postfix is running under the user postfix. Furthermore, selinux is enforcing.
I have no idea how it is making this determination. A guess would be since the postfix version is not displayed in the banner, it is making assumptions.
Post by shawniverson » 14 Jul 2019 14:17
Even the most recent vulnerability, CVE-2017-10140, has been fixed. v4 is running postfix version 3.3.0.
http://www.postfix.org/announcements/postfix-3.2.2.html
cphillips
Post by cphillips » 15 Jul 2019 13:52
shawniverson wrote:
14 Jul 2019 14:17
Thanks, I've raised a ticket with the scanning company for them to investigate as it does indeed look like false positives.
I'll report back what they say!
cphillips
Post by cphillips » 25 Jul 2019 12:36
Just to update this..
I had to disable TLS 1.0 and then prove that Postfix was 3.3.0 which then resulted in a PCI DSS pass!
Also had to setup a proper SSL certificate as the self generated one was failing.
Got there in the end.
