I am new to using eFA. I noticed I was getting items in quarantine for double file extensions. It looks like the gateway is trying to send out a DMARC report. I disabled DKIM and DMARC, however, after I did that I stopped receiving emails. As soon as I enabled the feature again I started getting emails. Is this normal? Is it a spam check feature or just a reporting feature or both?
Will eFa send the DMARC report itself? If it does wouldn't the the DKIM key need to be changed to match the key on the email server?
Fresh Install: DKIM And DMARC
cbritton1978
Re: Fresh Install: DKIM And DMARC
I guess this might be helpful
Currently running
centos-release-7-6.1810.2.el7.centos.x86_64
ESXi 6 Allocated 2 cpus 100GB 8GB Ram
MailWatch for MailScanner v1.2.12 running on eFa-4.0.0
Installed Via Kickstart
I am not at the greatest at Linux but searching the forum I used tail to view incoming mail
with DKIM And DMARC disabled I see this in the logs
postmap /etc/postfix/transport
Error went away but there's a new error
Currently running
Tried:Jun 21 10:49:53 scrollspam postfix/smtpd[10688]: warning: database /etc/postfix/transport.db is older than source file /etc/postfix/transport
Enabled DKIM and DMARC and receiving email again.Jun 21 11:15:58 scrollspam postfix/smtpd[14872]: NOQUEUE: milter-reject: EHLO from atl4mhfb04.myregisteredsite.com[209.17.115.120]: 451 4.7.1 Service unavailable
