Hi Guys,
after the last job Cron " CLAM antivirus" PDF attachements seems to be blocked.
[*]Clamd: message was infected: Win.Exploit.CVE_2019_0903-6966169-0
Clamd: Check 15 juni 2019.pdf was infected: Win.Exploit.CVE_2019_0903-6966169-0
The issue now is not every PDF is blocked however i am curious if other people are having this issue too or just the file is really explote .CVE.
files are ok on /etc/MailScanner
Thank you
PDF are blocked
PDF are blocked
Re: PDF are blocked
I would trust that message. That PDF may have a virus in it.
Re: PDF are blocked
This seems to be a false positive as I am even getting this from my Spamexperts PDF reports now
I guess a Clamav update in a day or so should resolve it.
Francesca
Francesca
Re: PDF are blocked
There is an issue with clamav pdf's scanning at the moment.
To temp solve it, and don't blame me if the message did report a valid (Win.Exploit.CVE_2019_0903-6966169-0) virus
1. Howto whitelist a clamav signature https://www.clamav.net/documents/how-do ... -signature
2. A more detailed ( copy and paste) solution https://marc.info/?l=clamav-users&m=155895964604136&w=2
It would make sense to review your security policy and to check your backup policy, before you whitelist any signatures.
Just take a look at Baltimore https://www.nytimes.com/2019/05/25/us/n ... imore.html
Re: PDF are blocked
i beleive Clamav has resolved this, last cron job got stuff set up.
anyone facing the same issue still ?
Henk allow signature is not smart thought !
