Refining your Scores
Post by nicola.piazzi »
efa.automasscheck.zip
(1.63 KiB) Downloaded 410 times
There is a great way to have more accurate scores !
You can partecipate in spamassassin community (https://ruleqa.spamassassin.org/) to have scores that consider also your samples and are more accurate also for you when you update official spamassassin channel.
I wrote a little instructions to do this within an EFA box
It is very very simple and takes about 30min daily for 15k mails
Read file contained into attached zip :-)
