question about user types
ovizii
Post by ovizii » 13 May 2019 04:44
I previously had only listed one user per domain as domain administrator, it looked like this:
https://monosnap.com/file/TMty0szOLSMhT ... F11tILsmiE
you notice the user name is the full domain. Seems that is no longer possible as I now get: "For all users other than Administrator you must use an e-mail address for the username"
any quick way to set defaults up for a domain without manually creating each and every user?
ovizii
Re: question about user types
Post by ovizii » 13 May 2019 04:45
Found this manual entry: https://docs.mailwatch.org/using/user-filter.html
is that how it works now? Should I rename my domain admin users?
Post by henk » 13 May 2019 13:36
Not sure if you mean this: viewtopic.php?t=3002
It's not recommended, but it works fine with me.
//Allow domain admins to create/edit/delete other domain admins from the same domain (not recommended, only for backward compatibility)
define('ENABLE_SUPER_DOMAIN_ADMINS',true);
//Allow the username of domain admins and normal users to not be in mail format (not recommended, only for backward compatibility)
define('ALLOW_NO_USER_DOMAIN',true);
ovizii
Post by ovizii » 14 May 2019 07:32
Yes, thanks henk, that is exactly what I meant but the link you posted is a bit confusing as the screenshot does not exactly fit the text you wrote there.
This is what I am confused about:
In previous MailWatch versions we could enter any username in a non valid email format, to generate 1 single quarantine report for all mail-users for a specific domain.
as far as I remember, if I simply entered a domain as username and added an email to that user, that email would receive a quarantine report for that whole domain.
Now if I look at your screenshot, the username is a full email address meaning that user will only receive a quarantine report for that particular email, or am I wrogn here? Shouldn't the username be: @localhost and the recipient email monitor@localhost?
Post by henk » 14 May 2019 14:04
You did remember well :D
As I use fetchmail to fetch mail form external sources, I map that to a local user. So every mail user has a user@localhost account on EFA. ( also dovecot is running ). The the recipient email is an admin user at my domain (my internal mailserver)
Just succesfull tested the domain only username: localhost
2019-05-14-User Management.png (15.42 KiB) Viewed 750 times
Result:
/usr/local/bin/mailwatch/tools/Cron_jobs/mailwatch_quarantine_report.php
 === Generating report for localhost type=D
 ==== Recipient e-mail address is test@mydomain.com
 ==== Building list for localhost
 ==== Found 4 quarantined e-mails
 ==== Sent e-mail to test@mydomain.com
 === Generating report for monitor@localhost type=D
ovizii
Post by ovizii » 15 May 2019 04:41
Thanks for confirming and digging out that old post. I did not have to add a new user in a while but when I tried adding 2 new domains and saw that all my old users were in a different format, I just vaguely remembered there was a reason for that but couldn't find where it was described :-)
I'll get to editing my config today so that I can keep using this old username format.
Gogo
Post by Gogo » 04 Jun 2019 07:22
I tried to follow that link but I'm not understanding the whole concept. Can anyone help out on this?
ovizii
Post by ovizii » 05 Jun 2019 10:43
I can try and explain how I understand the situation but I might be wrong.
Looking at https://docs.mailwatch.org/using/user-filter.html and viewtopic.php?t=3002
this is what I took away:
  • If you create a user named johndoe@example.com as user type User and I log-in as that user, I will only be able to see e-mail address to/from me and to be able to add Blacklist/Whitelist entries for my address (if enabled).
  • If you create a user named domain-admin@example.com as type Domain Administrator and I log-in as that user, I will only be able to see messages to/from my domain or create blacklist/whitelist entries for the entire domain or for a specific user. The domain in the mail address (part after @) will be used to identify the users domain. If username is not in format of a mail address this assumes the domain “no domain” and the domain admin will only be able to edit/see users that also have “no domain”.
  • The Administrator type can do anything for any user or domain.
If you enable this option:
you can also use example.com as username and assign this user the domain admin role.
annabellelee
Post by annabellelee » 28 Jun 2019 09:21
Thank you for the information.
