[eFa] - Set DCC Server Pools
[eFa] This option will allow you to set the DCC server
[eFa] pools that you want to use.
[eFa] The dcc-servers.net pool is limited use and what ships with dcc.
[eFa] Choice of pool may affect performance, depending on your location
Current DCC Pool:
Choose an option:
1) Use default pool (dccservers)
e) Return to main menu
[eFa] : 1
/var/eFa/lib/eFa-Configure/func_askdccservers: line 31: /usr/local/bin/cdcc: No such file or directory
/var/eFa/lib/eFa-Configure/func_askdccservers: line 32: /usr/local/bin/cdcc: No such file or directory
/var/eFa/lib/eFa-Configure/func_askdccservers: line 33: /usr/local/bin/cdcc: No such file or directory
/var/eFa/lib/eFa-Configure/func_askdccservers: line 34: /usr/local/bin/cdcc: No such file or directory
/var/eFa/lib/eFa-Configure/func_askdccservers: line 35: /usr/local/bin/cdcc: No such file or directory
[eFa] DCC Pool set to default
whereis cdcc
The cdcc path /usr/local/bin/cdcc should be:/usr/bin/cdcc
Check result with
cdcc info
