Mail delayed in Milter Incoming queue
DavidRa
Post by DavidRa »
Following the requested format here :)
1) I downloaded the official latest CentOS 7 ISO on 18 Apr from centos.org and checked its integrity
2) I created a virtual machine on Hyper-V with 4 CPUS, 8GB, Synthetic NIC, IDE for storage (Generation 1 - BIOS mode)
3) I have DHCP available on my instance's network and the instance can reach the Internet, and the instance can resolve DNS properly
4) I followed the instructions at https://github.com/E-F-A/v4/blob/master/BUILDING and followed the section "Building using kickstart and official repositories for testing"
5) The build had no errors
6) The install rebooted
7) I am using Chrome on Server 2016, and here is a description, of what is happening when I wait for test emails.
OK enough of that. I'm throwing some test emails at eFa using Telnet (I'm replacing email receipt currently handled by a Sophos firewall that's randomly breaking inbound emails). What I'm seeing is that the emails often sit in the Milter Incoming queue for 5 minutes or more before being processed. I might expect that except that the email is only 7 lines of text, no attachments, and 5 of the lines are headers:
Subject: Test email with a little more info
Date: Thu, 18 Apr 2019 23:30:08 1000
To: Test <Test@example.net>
Message-ID: a635293f-01c0-429f-b905-e1d6d2c5a1d8test
This is a test email with headers that make it fractionally less spammy.
I don't immediately see any tunables/configuration that might explain what's happening - I do have most of the configuration for this new deployment at defaults other than the number of MailScanner children. I do see the number of MSMilter children is zero - IDK why though.
Status table from MailWatch attached for initial insights. Thanks :)
Re: Mail delayed in Milter Incoming queue
The first tester that followed the requested format :dance: :clap: :violin:
Great firewall :whistle:
"emails often sit in the Milter Incoming queue for 5 minutes or more before being processed"
Did you have a look at /var/log/maillog and /var/log/messages?
DavidRa
Post by DavidRa »
henk wrote: 18 Apr 2019 18:02Great firewall :whistle:
Yeah it's not great.
I have reviewed both logs, but nothing jumped out at me - and now it appears to be operating normally. So perhaps I was just impatient - I'll keep an eye on it and post logs if there's anything obvious. Thanks though!
The discussion of firewalls is outside the scope of this forum, but as your first line of defense, it's worth the effort to pick a decent firewall.
Can't say anything about the sophos firewall, but I'm a big fan of pfsense community edition. https://docs.netgate.com/
Easy to install/update/configure, extremely flexible with a lot of features (DNS , IDS, DNSBL, DHCP, VPN, etc, etc.) a set of tools and a webinterface to manage all components.
