ERW steel tube suppliers
Testing of eFa 4
jthan123
Post by jthan123 » 17 Apr 2019 01:46
European Standard BS1387 ERW Welded Steel Pipe For oil gas pipeline scaffolding using
Details for BS1387 standard ERW welded steel pipe:
Product NameBS1387 standard ERW welded steel pipe
MaterialQ195—Grade B, SS330, SPC, S185
Q215—Grade C,CS Type B, SS330, SPHC
Q235---Grade D, SS400, S235JR, S235JO, S235J2
Q345---SS500, ST52
StandardASTM A53, BS EN 10296-2006, BS EN10219, BS1139, JIS G3444-2006, JIS G3445-2006, API, GB, ASTM,BS1387-1985, GB/T3091-2001
Size1.Out Diameter: 21.3mm-609mm
2. Wall Thickness: 1.5-22mm
3. Length: 5-12m
Surface TreatmentGalvanized, 2PE/3PE, varnish coating, black or color painted, FBE, inside plastic coated or as per customer's requirement.
End TreatmentEnds plain or beveled
TestChemical Component Analysis, Mechanical Properties( Ultimate tensile strength, Yield strength , Elongation), Technical Properties( Flattening Test, Bending Test), Exterior inspection, Dimensional and Visual Inspection.
Addition:Special design available according to requirment; Anti-corrosion and high temperature resistant ; All the production process are made under the ISO9001:2000 strictly
ApplicationWater delivery, underground linepipe, conduit, drainge pipe, petroleum, natural gas and so on.
Main marketAsia, Middle East, Africa, South America etc.
Chemical components and mechanical property:
Stan-
dard Trade
markChemical componentsMechanical property
CSiMnPSCuNiMoCrVTensile
StrengthYield
StrengthElongation
ASTM
A53A≤0.25/≤0.95≤0.05≤ 0.06≤0.40≤0.40≤0.15≤0.40≤0.08≥330≥205≥29.5
B≤0.30/≤1.2≤0.05≤ 0.06≤0.40≤0.40≤0.15≤0.40≤0.08≥415 ≥240≥29.5
Stan-dard Trade mark Chemical components Mechanical property
CSiMnP,S Cu Ni Mo Cr VTensile Strength Yield
Strength Elongation
ASTM
A106B ≤0.30 ≥0.100.29-1.06 ≤0.035 ≤0.40 ≤0.40≤0.15 ≤0.40 ≤0.08 ≥415 ≥240≥30
C≤0.35 ≥0.10 0.29-1.06≤0.035 ≤0.40 ≤0.40 ≤0.15 ≤0.40≤0.08 ≥485 ≥275 ≥30
Packing and Loading for BS1387 standard ERW welded steel pipe:
A. In hexagonal bundle by steel strips
B. With water-proof bag
C. In bulk
d. According to requests
20ft GP: 5898mm(Length)x2352mm(Width)x2393mm(High) 25~27 Ton
40ft GP: 12032mm(Length)x2352mm(Width)x2393mm(High) 25~27 Ton
FAQ:
1.Q.Are you a factory or not?
A.Yes we are a leading pipe manufacturer whose factory in Tianjin. Welcome to visit our factory.
2.Q.How about the Delivery Time?
A.The products will be produced since we get your deposit by T/T or your original L/C.For normal sizes,some stocks in our factory now,we can supply once you need.
3.Q.What kind of payment does your company support?
A.T/T,100% L/C at sight,Cash,Western Union are all accepted.
4.What's your advantages ?
More than 59 hot 165x1.5mm pre-threading galvanized pipe with pvc cap manufacturer production lines,34 erw steel pipe production lines, top 500 enterprise of china .Key projects: the 2008 Olympic games venues,the 2010 Shanghai world expo exhibition hall,the capital international airport,etc. ERW steel tube suppliers
website:http://www.zhaolidasteel.com/steel-pipe/erw-pipe/
