clamd just keeps dying
Stuart
Post by Stuart »
Our server is unable to process mail, as clamd keeps dying.
service clamd status
shows
clamd dead but subsys locked
Removing the lock and restarting the services allows a few emails through, before dying again.
EFA version 3.0.2.6 (Downloaded eFa 3.0.2.5 Hyper-V image and updated immediately)
Server has 10GB of RAM available;
               total         used          free             shared   buffers   cached
Mem:       9875412    2321608    7553804       1588      25164     851700
-/+ buffers/cache:    1444744    8430668
Swap:      4194300          0    4194300
It had been running perfectly fine since deployment. Nothing was changed, this just started happening. I have cleared the queue and tested. I have bypassed the server, and clamd ran for more than a day okay, as no mail hit the queue. As soon as I sent email to it, clamd died again. Have rebooted multiple times. I have not been able to find anything that helps me resolve the issue.
ANY suggestions on what to check and where to look would be appreciated.
Thank you.
Re: clamd just keeps dying
Stuart
Post by Stuart »
I disabled Yara as per the topic. Has been running for about half an hour okay.
Thank you!
