(how-to) sophossavi installation guide
Post by nicola.piazzi » 01 Apr 2019 14:29
Adding an antivirus to Efa / MailScanner means to add a cpu intensive process that is inaccettable for me
I found that without antivirus each messages takes about 3 / 5 sec/cpu to be processed for spam
Adding an antivirus can take additional 5 / 15 sec/cpu
So total server Cpu increase a lot and can be inaccettable
Only clamd and sophossavi have a daemon that runs in memory and are cpu inexpensive
clamd is included in efa instalaltion
sophossavi was difficoult to use because was written in 32bit and is undocumented
I wrote these simple instructions to install and use it
Please note that i am talking of sophossavi and not sophos option in MailScanner.conf
If someone try this can tell me about it
EFA.SophosSavi_Install_Centos6_64.zip
(1.78 KiB) Downloaded 24 times
uzisuicida
Re: (how-to) sophossavi installation guide
Post by uzisuicida » 02 Apr 2019 19:34
I'm going to try it, and I'll tell you how it goes.
Post by nicola.piazzi » 09 Apr 2019 08:08
Sophos SAVI works well
mac.linux.free
Post by mac.linux.free » 09 Apr 2019 13:05
works for me, too. :clap:
Post by nicola.piazzi » 09 Apr 2019 13:22
this is great because antivirus not daemonized are unusable for me
before i used clamav and sophos
changing to sophosavi i reduced efa vm from 12 to 4 cpu !
musabr187
Post by musabr187 » 16 Apr 2019 08:24
Hi Nicola,
It’s working. Thanks for your document.
How did you add Sophos SAVI on Virus report? It’s not showing up in scanner column.
Post by nicola.piazzi » 16 Apr 2019 08:28
Nothing done in virus report, if you dont see i suppose you havent received viruses detected by savi at now
musabr187
Post by musabr187 » 16 Apr 2019 09:19
It's not catching test virus 'EICAR-AV-Test' on the report.
Post by nicola.piazzi » 16 Apr 2019 09:22
EICAR CATCH is excluded by report, you need to include it modifiyng source or wait to receive virus
musabr187
Post by musabr187 » 16 Apr 2019 09:26
Okay, thanks. Waiting for virus :)
Post by nicola.piazzi » 16 Apr 2019 09:29
i modified report but i dont remember where
if you have echange consider to use OW plugin
musabr187
Post by musabr187 » 16 Apr 2019 09:35
Okay, I'll check it out later.
musabr187
Post by musabr187 » 17 Apr 2019 04:24
Password protected zip file is blocked by SophosSAVI '.zip caused an error: File was encrypted (530)', where I need to change to disable this.
Post by nicola.piazzi » 17 Apr 2019 09:21
somewhere there is this, buit for me is ok so
musabr187
Post by musabr187 » 17 Apr 2019 09:25
##Allowed Sophos Error Messages =
Allowed Sophos Error Messages = "File was encrypted", "Password protected file"
This will allow encrypted/password protected files to pass.
