Need your help : strange problem to release mails
woundride
Post by woundride » 14 Mar 2019 18:18
I request your help please for very a strange problem.
Since 1 day, I can't release quarantine's messages received.
I've tried with mailwatch Web interface, also with sendmail command, and have the same problem.
When I edit a message's file and delete "some headers", I can release message with sendmail command and also from mailwatch :
sendmail -t </var/spool/MailScanner/quarantine/today/folder/MESSAGE.ID
When I try to release an older message who have 5 days ago for exemple, I've not this problem. I can release the message from mailwatch also from sendmail command.
I've verified the permissions and they are similar :
-rw-rw---- 1 postfix mtagroup
I've verified the type of files, and they are also similar :
RFC 822 mail text
Someone have an idea to find a track to resolve this issue ?
Thanks,
Kind regards,
Charles
woundride
Re: Need your help : strange problem to release mails
Post by woundride » 15 Mar 2019 12:05
After more tests, I've found the header who block release function.
When I modify Message-ID, for example :
Message-ID: <1>
I can release messages.
I carry on my investigations.
Best regards,
Charles
woundride
Post by woundride » 15 Mar 2019 12:25
When I see Message-ID header on old message for that have not problem to release, I've no $ caracter, for exemple :
Message-Id: <201905031331.4s8hr9pb5fq3fj@XXX.com>
Since 2 days, the messages have some $ caracters :
Message-ID: <009501d4db11$f4082b10$dc188130$@XXX.com>
I've looked on MailScanner.conf, but I've not found solution.
Someone have an idea please ?
Best regards,
Charles
woundride
Post by woundride » 15 Mar 2019 12:38
Issue solved :
In MailScanner.conf I've added Message-Id in Removed headers :
Remove These Headers = X-Mozilla-Status: X-Mozilla-Status2: Disposition-Notification-To: Return-Receipt-To: Message-Id:
News ID have no $ but - :
Message-ID: <11a7ce82-d6c2-27a0-9b03-f173d1f13cb5@XXX.com>
It works !
Post by henk » 16 Mar 2019 00:16
Remove all headers is somewhat overkill. :shifty:
1. What version are you on?
2. What changed the day before this issue popped up?
3. Some details would help
There is a similar old and resolved issue viewtopic.php?f=13&t=2447&p=9607#p9607
woundride
Post by woundride » 18 Mar 2019 12:05
Hi henk,
Thanks for your answer, I'v solved my issue.
For information, I'm running EFA-3.0.2.6.
My problem is different, is comming from MailScanner configuration, I've needed to remove orginal Message-Id header to release messages from quarantine.
You can see, all details of my investigation and the resolution of this issue in my messages's history.
Best regards,
Charles
