EFA4 Initial SSH
Posted: 09 Mar 2019 11:27
In the process of testing efa4 I did want to change some settings before the Initial configure script.
As root will not be able to login ( due ssh policy and Selinux) and service sshd is disabled, as good security policy, by default
To be able to login with SSH. ( to be able to copy and paste and watch the configure process and logs)
Do not use this user to exec the install script!
First create tmp admin user for SSH access
Decide if you want to enable ssh
Start sshd
When finisched you can delete the tmp admin user and use the CLI user created by the EFA configure script, or even disable ssh.
useradd admin
usermod -aG wheel admin
passwd adminCode: Select all
systemctl enable sshdCode: Select all
systemctl start sshd
