I have placed some forwarding config in this file /etc/unbound/conf.d/forwarders.conf and everything works fine. However, I changed my IP on the server and this file was removed. Is this expected? If so, is there a different directory I should be storing manual configuration to avoid it being removed automatically?
Thank you
