purge or delete messages
mattch
Post by mattch »
i hope this is the right place to ask. any pointer or suggestion much appreciated!
how can i remove messages in quarantine, mass delete all of them? a folder?
#i try to set in /var/www/html/mailscanner/conf.php
define('QUARANTINE_DAYS_TO_KEEP', 0);
#and force it by
/usr/local/bin/mailwatch/tools/Cron_jobs/mailwatch_quarantine_maint.php --clean
but i dont think this is correct method and didnt work for me anyway.
i have 7000 messages hanging around on mailwatch that makes my ocd kick in high gear:
Cron <clam@ > [ -x /usr/bin/clamav-unofficial-sigs.sh ] && /bin/bash /usr/bin/clamav-unofficial-sigs.sh > /dev/null
doing this stopped the messages but now i want to clean them up
yararulesproject_enabled="no"
enable_yararules="no"
sudo rm /var/lib/clamav/*yar
sudo rm /var/lib/clamav/*yara
sudo service clamd start
thank you!
Re: purge or delete messages
This is the right place to ask questions :D
You mention "7000 messages hanging around on mailwatch that makes my ocd kick in high gear".
I you wake up and your house is on fire, that should kick you in high gear, not having a some mail ;)
To manage the number of mail entries, you have 2 options. (Your assumed MailScanner version: 5.0.7)
// Define how many days of emails to keep.
define('RECORD_DAYS_TO_KEEP', 60);
/* Quarantine settings */
// The quarantine flag is available from MailScanner 4.43.
// It will drammatically improved the speed of quarantine operations
// but requires that you use the quarantine_maint.php in place of
// the clean.quarantine script provided with MailScanner.
define('QUARANTINE_USE_FLAG', true);
define('QUARANTINE_DAYS_TO_KEEP', 30);
next in /etc/MailScanner/defaults
## Cron Job Actions
# MailScanner cron jobs are executed like this:
# hourly items: /usr/sbin/ms-cron HOURLY
# daily items:  /usr/sbin/ms-cron DAILY
# daemon check: /usr/sbin/ms-cron CHECK
# maintenance:  /usr/sbin/ms-cron MAINT
# This sets how many days files will remain in the "quarantine" area before
# being automatically removed. Set to 0 (zero) to disable.
# This is executed during the MAINT cron option.
q_days=30
mattch
Post by mattch »
henk wrote: 17 Feb 2019 23:35 I you wake up and your house is on fire, that should kick you in high gear, not having a some mail ;)
:lol: :doh: :pray:
:angry-extinguishflame: :angry-screaming: :banana-skier:
thanks!
