New issue... just discovered it the other day.
When making changes at the console using the configuration menu, changes are not saved.
For example, drop into the sub-menu "8) Mail Settings" then select "3) Admin Email" and change the address, go back up to the main menu, then drop back in and look, the e-mail address was not changed.
Any suggestions?
EFA-Configure does not save changes.
- bikertrash
Re: EFA-Configure does not save changes.
A bug in that part of the interface...
Here's the configs to change to work around it for now:
/etc/EFA-Config
/etc/aliases
Run the following:
/etc/EFA-Config
ADMINEMAIL:me@example.com
root: me@example.com
Unscanned Header Value = Please contact me@example.com for details
Information Header Value = Please contact me@example.com for more information
sudo newaliases
sudo service mailscanner restart
- bikertrash
As always.... thank you shawniverson!
