uzisuicida
Post
by uzisuicida »
Hello with everyone,
Recently install version 3.0.2.6, when an email is marked as spam, it is put in quarantine, but I do not have the option to release the message.
Show only this:
But in another installed version, it shows me this:
Post
by henk »
best option is to compair the config files from the ' current' and the 'other' efa
Do you have Spam Actions = store?
searching this forum will show several posts on this topic.
viewtopic.php?t=971
viewtopic.php?t=2189
uzisuicida
Post
by uzisuicida »
Hi henk,
problem solved deleting these files:
/var/www/html/mailscanner/temp/GeoIP.dat
/var/www/html/mailscanner/temp/GeoIPv6.dat
Post
by henk »
You could replace the geoip files with a recent copy
viewtopic.php?t=3311
