Custom bad sites Phishtank.com
Alleyviper
Post by Alleyviper » 22 Jan 2019 22:30
Hi there,
Hourly updated phishing sites from phishtank.com
Here I just added a cron for updating daily
a) Create an account at http://phishtank.com
b) create API Key by giving a APP name
c) This is the Database to be downloaded
http://data.phishtank.com/data/online-valid.php_serialized
Now we need to populate the following file:
/etc/Mailscanner/phishing.bad.sites.custom
d) To do so, first create a new cron file at:
/etc/cron.daily/
Do
nano /etc/cron.daily/<YourCronFileName.sh>
e) Add the following:
#!/bin/bash
# www.phishtank.com | Phishing Sites                               #
# Clear Screen
clear
# Get into Mailscanner Folder
cd /etc/MailScanner/
# Create phishing.bad.sites.custom Template
cp phishing.bad.sites.custom phishing.bad.sites.custom.template
sed -i '/cp phishing.bad.sites.custom phishing.bad.sites.custom.template
# Delete Old phishing.bad.sites.custom and create new file from phishing.bad.sites.custom.template
rm -rf /etc/MailScanner/phishing.bad.sites.custom
cp phishing.bad.sites.custom.template phishing.bad.sites.custom
# Download database
wget http://data.phishtank.com/data/<YourApiKey>/online-valid.php_serialized
# Get only urls from database and remove www.phishtank.com urls | Get clean phishtank
cat online-valid.php_serialized | grep -Eo "(http|https)://[a-zA-Z0-9./?=_-]*" | sort | uniq > phishtank
sed -i '/www.phishtank.com/d' phishtank
# Delete downloaded database from phishtank.com
rm -rf /etc/MailScanner/online-valid.php_serialized
# Update phishing.bad.sites.custom from phishtank
cat phishtank >> phishing.bad.sites.custom
# Delete phishtank
rm -rf /etc/MailScanner/phishtank
# Reload Mailscanner
/etc/init.d/mailscanner reload
# Cleanup
clear
echo "Finished"
f) Make it executable
chmod +x /etc/cron.daily/<YourCronFileName.sh>
g) Check if it works:
./etc/cron.daily/<YourCronFileName.sh>
h) Your phishing.bad.sites.custom should be now populated with urls being used in phishing.
Note: This is a rough script for getting it done
:dance:
thewomble
Re: Custom bad sites Phishtank.com
Post by thewomble » 25 Jan 2019 16:48
Alleyviper ok I have downloaded and it works, thanks.
But how does EFA use this data?
I went to www.phishtank.com and took the url at the top of the list added it into phishing.bad.sites.custom
saved it
reloaded MailScanner
sent myself an email externally with the phishing url
Could not see how it used this data at all from the score.
AWL scored it -9 and Bayes -1.9, only becuase it was on SpamHaus list it scored enough to be blocked.
-9.34	AWL	Adjusted score from AWL reputation of From: address
-1.90	BAYES_00	Bayes spam probability is 0 to 1%
0.10	DKIM_SIGNED	Message has a DKIM or DK signature, not necessarily valid
-0.10	DKIM_VALID	Message has at least one valid DKIM or DK signature
-0.10	DKIM_VALID_AU	Message has a valid DKIM or DK signature from author's domain
-2.00	DMARC_PASS	DMARC:validation seems valid
-1.00	DMARC_SPF_PASS	DMARC:SPF validation passes
0.00	FREEMAIL_FROM	Sender email is commonly abused enduser mail provider
0.00	HTML_MESSAGE	HTML included in message
2.00	JA_URIBL_AB_SURBL	Contains an URL listed in the AB SURBL blocklist
-0.10	MAILMX_TLS	TLS:Message seemed to have been received by using TLS to Mailmx
3.00	PYZOR_CHECK	Listed in Pyzor (https://pyzor.readthedocs.io/en/latest/)
-0.00	RCVD_IN_DNSWL_NONE	Sender listed at http://www.dnswl.org/, no trust
-0.90	SENDERSCORE_87	SenderScore Reputation 87% (score.senderscore.com)
-1.00	SO_PUB_SNDR_DOMAIN_DKIM_60	Sender's domain DKIM is listed in reputation-sender-60.rbl.scrolloutf1.com
1.00	SO_PUB_URIBL_NS_40	URL's ns address is listed in reputation-ns-40.rbl.scrolloutf1.com
-0.00	SPF_HELO_PASS	SPF: HELO matches SPF record
-0.00	SPF_PASS	SPF: sender matches SPF record
1.25	URIBL_ABUSE_SURBL	Contains an URL listed in the ABUSE SURBL blocklist
2.50	URIBL_DBL_PHISH	Contains a Phishing URL listed in the Spamhaus DBL blocklist
15.00	URIBL_DBL_SPAMHAUS	URI's listed in Spamhaus DBL (dbl.spamhaus.org) DNSBL
1.62	URIBL_SBL	Contains an URL's NS IP listed in the Spamhaus SBL blocklist
0.10	URIBL_SBL_A	Contains URL's A record listed in the Spamhaus SBL blocklist
-1.10	WDKIM_PASS	DKIM:Successful verification. DKIM Signature exists, selector in signing domain exists, and the required headers are unmodified.
0.10	W_DKIMWL_Freemail	DKIMWL.org - Freemail
0.10	W_DKIMWL_Med	DKIMWL.org - Med scoring
Post by henk » 25 Jan 2019 17:04
I disabled AWL en enabled TxRep. In the new efa4 TxRep is default, since AWL had some issues, just google on it.
I can confirm TxRep works :!:
Alleyviper
Post by Alleyviper » 25 Jan 2019 20:28
Hi thewomble,
The email will just be blocked. I see no log on EFA yet.
I've sent an e-mail from gmail to a domain protected by EFA and got a blocked sent message at gmail.
Message blocked
Your message has been blocked by email@domain.tld. See details for ...
The details...
Message rejected. See https://support.google.com/mail/answer/69585 for more information.
Alleyviper
Post by Alleyviper » 31 Jan 2019 20:50
Hi Henk,
Can you provide steps for:
It is good for documentation and I'm just not an expert on this :D
Post by henk » 31 Jan 2019 21:28
Using eFa forum als documentation :whistle:
Just google why change from AWL to TxRep :shifty: https://wiki.apache.org/spamassassin/AwlWrongWay
Compair your files and make the changes. ( the # must match your config to :!: )
The configs:
/etc/mail/spamassassin/v310.pre
# AWL - do auto-whitelist checks
#loadplugin Mail::SpamAssassin::Plugin::AWL
/etc/mail/spamassassin/v341.pre
# TxRep - Reputation database that replaces AWL
loadplugin Mail::SpamAssassin::Plugin::TxRep
/etc/MailScanner/spamassassin.conf
# now turned on by default
# use_auto_whitelist 0
#auto_whitelist_factory Mail::SpamAssassin::SQLBasedAddrList
txrep_factory Mail::SpamAssassin::SQLBasedAddrList
txrep_track_messages 0
user_awl_sql_override_username TxRep
user_awl_sql_table txrep
use_txrep 1
#End E.F.A. mods for MySQL
And check the SpamAssassin Rule Hits via Search and Reports after some time. The TXREP score will be visible as TXREP Score normalizing based on sender's reputation
Alleyviper
Post by Alleyviper » 31 Jan 2019 21:56
Hi Henk,
Thanks a lot for starts, I just got half way to it, that is why I've asked for help :)
Just to confirm.. at:
#Begin E.F.A. mods for MySQL
bayes_store_module              Mail::SpamAssassin::BayesStore::SQL
bayes_sql_dsn                   DBI:mysql:sa_bayes:localhost
bayes_sql_username              sa_user
bayes_sql_password              <password>
user_awl_dsn                    DBI:mysql:sa_bayes:localhost
user_awl_sql_username           sa_user
user_awl_sql_password           <password>
bayes_sql_override_username     mailwatch
use_txrep                       1
Is this ok?
Best regards.
Alleyviper
Post by Alleyviper » 31 Jan 2019 22:13
Hi Henk,
We have a bypass situation here. I've sent an URL from phishtank and it was correctly blocked.
Notice: This message is shown at gmail and no info on EFA.
Message blocked Your message has been blocked by email@domain.tld. See the technical details below for more information. KNOW MORE
Nevertheless, if I use the same URL encoded in a Google short link the message passes clean.
I Will Research if there is a SpamAssassin plugin to check the url final destination and block if there is a match.
Do you know any existing plugin?
Here goes the scoring on the bad link Google shortned:
Score	Matching Rule	Description
4	requerido
0.00	KAM_SHORT	Use of a URL Shortener for very short URL
The relevant Score is this:
Best regards.
benscha
Post by benscha » 04 Mar 2019 15:06
Hi Guys
i have extended the Script with some Blacklists.
  • ransomwaretracker.abuse.ch
  • malwaredomains.com
#!/bin/bash
# Clear Screen
clear
\cp -fR phishing.bad.sites.custom phishing.bad.sites.custom.template
# Download BAD URLS
wget http://data.phishtank.com/data/3e71373433fe683add611bf2e3fd2efa34265c134c4b7bed2b5ab9e998af4855/online-valid.php_serialized -O /tmp/phishtank.txt
wget https://www.openphish.com/feed.txt -O /tmp/feed.txt
wget https://ransomwaretracker.abuse.ch/downloads/RW_URLBL.txt -O /tmp/rw_urlbl.txt
wget https://ransomwaretracker.abuse.ch/downloads/RW_DOMBL.txt -O /tmp/rw_dombl.txt
wget http://mirror2.malwaredomains.com/files/immortal_domains.txt -O /tmp/immortal_domains.txt
# Remove the first 7 Lines drom Blacklist Files
sed -i 1,7d /tmp/rw_urlbl.txt
sed -i 1,7d /tmp/rw_dombl.txt
cat /tmp/phishtank.txt | grep -Eo "(http|https)://[a-zA-Z0-9./?=_-]*" | sort | uniq > /tmp/phishtank
sed -i '/www.phishtank.com/d /tmp/phishtank
rm -rf /tmp/phishtank.txt
cat /tmp/phishtank >> /etc/MailScanner/phishing.bad.sites.custom
cat /tmp/feed.txt >> /etc/MailScanner/phishing.bad.sites.custom
cat /tmp/rw_urlbl.txt >> /etc/MailScanner/phishing.bad.sites.custom
cat /tmp/rw_dombl.txt >> /etc/MailScanner/phishing.bad.sites.custom
cat /tmp/immortal_domains.txt >> /etc/MailScanner/phishing.bad.sites.custom
# Delete phishtank
rm -rf /tmp/feed.txt
rm -rf /tmp/rw_urlbl.txt
rm -rf /tmp/rw_dombl.txt
rm -rf /tmp/immortal_domains.txt
# Load Custom Bad URLS
cat /scripts/bad_mail_urls >>/etc/MailScanner/phishing.bad.sites.custom
wc -l /etc/MailScanner/phishing.bad.sites.custom | mail -s "Phishing Sites" report.recipient@domain.com
# Cleanup
clear
echo "Finished"
:violin: cheers
always happy for any hints and tipps! :clap: | EFA 3.0.2.6
Alleyviper
Post by Alleyviper » 04 Mar 2019 16:04
Nice ;)
ovizii
Post by ovizii » 05 Mar 2019 12:14
I do think adding phishtank is unnecessary as after reading this old thread it seems it is or was already incorporated: viewtopic.php?f=14&t=1736
/etc/MailScanner/phishing.bad.sites.conf USED to include this line:
# This file is updated once per day from http://www.phishtank.com.
that line has disappeared so I guess we need to figure out if it still gets updated from phishtank...
ovizii
Post by ovizii » 05 Mar 2019 12:16
@alleyviper: you should add this to the github issue tracker as a feature suggestion for EFA v4 though => https://github.com/E-F-A/v4/issues
Woger
Post by Woger » 25 Mar 2019 10:09
Thanks for the script but it gives an error on this line:
because of the single '
But I can't figure out where the closing ' should be.
The phishing.bad.sites.custom seems ok.
Also, it's not working. And I think it's because spamassassin is not loading .custom files. I have also a phishing.bad.sites.conf which is generated by EFA itself.
Greetings,
Roger
cdburgess75
Post by cdburgess75 » 23 Oct 2019 15:38
Updated Script: (works for me)
#!/bin/bash
# Phishing Sites #
# Clear Screen
clear
#sed -i '/
# Download BAD URLS
wget http://data.phishtank.com/data/3e713734 ... serialized -O /tmp/phishtank.txt
wget https://ransomwaretracker.abuse.ch/down ... _URLBL.txt -O /tmp/rw_urlbl.txt
wget https://ransomwaretracker.abuse.ch/down ... _DOMBL.txt -O /tmp/rw_dombl.txt
#wget http://mirror2.malwaredomains.com/files ... omains.txt -O /tmp/immortal_domains.txt
sed -i '/www.phishtank.com/d' /tmp/phishtank
#cat /tmp/immortal_domains.txt >> /etc/MailScanner/phishing.bad.sites.custom
# Delete phishtank
wc -l /etc/MailScanner/phishing.bad.sites.custom | mail -s "Phishing Sites" email@yourself.com
rm -rf /etc/MailScanner/phishing.bad.sites.conf
sed -e 's/http[s]\?:\/\///g' /etc/MailScanner/phishing.bad.sites.custom > /etc/MailScanner/phishing.bad.sites.conf
echo "Finished"
