Migration
fastbone
Migration
Post by fastbone »
Are there any instructions/tools to migrate existing data from 3.x to 4?
jamerson
Re: Migration
Post by jamerson »
Please stay tuned we are testing the migration tools
Re: Migration
Migration testers are needed!
Justin
Re: Migration
Post by Justin »
shawniverson wrote: 26 Jan 2019 20:25 Migration testers are needed!
Feel free to PM me.
I can clone my production VM to provide migration tests.
sbozzy
Re: Migration
Post by sbozzy »
Also available for migration testing, I have a 3.0.2.6 VM that I can clone for testing as well.
PM if you need.
Re: Migration
Going to start migration testing here soon, and will make step-by-step instructions for everybody to try in a test environment/clone...
jkissane
Re: Migration
Post by jkissane »
Similar to the above, shouldn't be a problem cloning our existing efa VM to test a migration.
Re: Migration
Re: Migration
I tested the migration as documented. I've no opendkim installed. Almost perfect :)
First I did a yum update. Massive update and copyed the latetest backup to the new efa and started restore.
issue 1
/var/log/maillog
Feb 2 21:24:18 sansspam sqlgrey: 2019/02/02-21:24:18 Server closing!
Feb 2 21:24:18 sansspam sqlgrey: Couldn't unlink "/var/run/sqlgrey.pid" [Permission denied]
Feb 2 21:38:32 sansspam MailScanner[9379]: MailScanner Email Processor version 5.1.3 starting...
looks like : the /etc/sqlgrey/sqlgrey.conf is restored to the v3 version with old /var/run path
issue 2
The bayes database is restored, but no access via the Gui.
2019 Bayes Database Info.png (2.26 KiB) Viewed 30612 times
Not clear why.
Only Import bayes works fine:
On v3 :
backup bayes
sa-learn --backup > backup.txt
On v4
Clear and restore bayes backup
sa-learn --clear
sa-learn --restore backup.txt
No need to mention that additional scanners like Sophos should be installed manualy :shifty:
==============<<<<<<<<<<Migration messages >>>>>>>>>>>========================
eFa v3 backup detected, performing migration...
Added new: Milter Max Children = 10
Added new: Milter Dispatcher = postfork
Added new: Milter PID File = /var/run/MSMilter.pid
Added new: MSMail Queue Type = long
Added new: MSMail Delivery Method = QMQP
Added new: MSMail Socket Type = unix
Added new: MSMail Socket Dir = /var/spool/postfix/public/qmqp
Added new: MSMail Relay Port = 25
Added new: MSMail Relay Address = 127.0.0.1
Added new: Milter Ignore Loopback = no
Added new: Milter Scanner = yes
Added new: Milter Port = 33333
Added new: Milter Bind = 127.0.0.1
Added new: Highlight Hidden URLs = no
Added new: Web Bug Replacement = http://dl.efa-project.org/static/1x1spacer.gif
Added new: Quarantine Denial Of Service = yes
Added new: Spam List Skip If Authenticated = no
Added new: Lockfile Dir = /var/spool/MailScanner/incoming/Locks
Added new: include /etc/MailScanner/conf.d/*
Re: Migration
Documentation updated, and fixed sqlgrey.conf issue in update 23.
Re: Migration
Migration, second try.
I reverted EFA4 to the situation before the yum update. ( after the kickstart build and eFa configure)
1. yum check-update and a yum update
2. reboot
3. Copy the EFA backup and the bayes backup to efa 4
4. Restore EFA backup ( Option 12)
- After the restore backup bayes data is not visible via the gui.
5. Clear bayes database via the Gui ( TOOLS AND LINKS-> SpamAssassin Bayes Database Info-> Clear Bayes Database)
6. Restore bayes ( sa-learn --restore backup.txt)
7 . Login and watch the miracle of your new Efa 4 with all the data from Efa3, without any error :clap: :dance: :violin:
jkissane
Re: Migration
Post by jkissane »
I'll give this a try tomorrow as bit too busy at work today.
jamerson
Re: Migration
Post by jamerson »
i have migrated today like 6 EFAS and everything seems fine,
i've even migrated the MariaDB from one box to other.
Re: Migration
The best final test is a reboot :oops: :oops:
As I continued the test, I noticed sqlgrey could not access mysql after the migration.
 systemctl status sqlgrey
● sqlgrey.service - SQLgrey Postfix Grey-listing Policy service
Active: inactive (dead) since Wed 2019-02-06 19:22:15 CET; 6min ago
1 efa systemd[1]: Started SQLgrey Postfix Grey-listing Policy service.
1 efa sqlgrey[13581]: dbaccess: can't connect to DB: Access denied for user 'sqlgrey'@'localhost' (using password: YES)
1 efa sqlgrey[13581]: dbaccess: error: couldn't get now() from DB: Access denied for user 'sqlgrey'@'localhost' (using password: YES)
1 efa sqlgrey[13581]: dbaccess: error: couldn't access config table: Access denied for user 'sqlgrey'@'localhost' (using password: YES)
1 efa sqlgrey[13581]: 2019/02/06-19:22:15 Server closing!
1 efa systemd[1]: Stopping SQLgrey Postfix Grey-listing Policy service...
1 efa systemd[1]: Stopped SQLgrey Postfix Grey-listing Policy service.
The v3 password is correctly set is de mysql.user table and in /etc/eFa/SQLGrey-Config
However, the /etc/sqlgrey/sqlgrey.conf still contains the v4 password ( and 2 duplicate entries)
## Database settings
# instead of Pg below use "mysql" for MySQL, "SQLite" for SQLite
# any DBD driver is allowed, but only the previous 3 have been tested
db_type = mysql
db_type = mysql duplicate entry should be removed#####
db_name = sqlgrey
db_name = sqlgrey duplicate entry should be removed####
# Note: the following are not used with SQLite
db_host = localhost
db_port = default
user = sqlgrey
db_pass = ***the efa4 password before migration*** remove this one
db_pass = <<password from /etc/eFa/SQLGrey-Config or the .v3 sqlgrey.conf>>
systemctl restart sqlgrey && systemctl status sqlgrey
Loaded: loaded (/usr/lib/systemd/system/sqlgrey.service; enabled; vendor preset: disabled)
Drop-In: /etc/systemd/system/sqlgrey.service.d
└─override.conf
Process: 13558 ExecStart=/usr/sbin/sqlgrey -d (code=exited, status=0/SUCCESS)
Main PID: 13581 (code=exited, status=0/SUCCESS)
