Outbound traffic issues
Justin
Post by Justin » 08 Jan 2019 10:54
Hi there,
I'm trying to get the outbound feature to work but for some reason it's not working.
I've got a Send Connector in Exchange which relays it to "mx.domain.com" which is the EFA server.
Tried using with and without authentication.
It tries to send it and afterwards it throws the email to our other Send Connector on our other Exchange servers.
Any guide to properly setup the outbound feature? (Sending from Exchange through EFA)
Kind regards,
Justin
Justin
Re: Outbound traffic issues
Post by Justin » 10 Jan 2019 09:30
Anyone?
And does anyone know which credentials i need to enter for Authenticated SMTP for EFA in Exchange?
Post by henk » 10 Jan 2019 11:07
Hi Justin,
As there are many members using exchange, and EFA for in en outbound, there should be some response..
Long time ago, you posted this question before: viewtopic.php?&t=2041
Somewhat confusing authentication: Exchange -> EFA (authenticated with SMTP ISP) -> Deliver address
I don't use exchange and use EFA only for inbound, but the relay authentication concept should be the same, I think.
Just google on
SMTP Authentication with Postfix
On my NON Exchange mailserver(s) I also need to authenticate the relay server.
/etc/postfix/main.cf
relayhost = [smtp.xyx.ru]
#Create hash from maps file (remember to do it each time you change your maps file):
#  postmap /etc/postfix/relay_passwd
smtp_sasl_password_maps = hash:/etc/postfix/relay_passwd
smtp.xyz.ru <<the-user>>:<<STRONG_PASSWORD>>
Justin
Post by Justin » 10 Jan 2019 11:16
henk wrote:
10 Jan 2019 11:07
Hi Justin,
Just google on
Hi Henk,
Thank you for your reply.
This time we are not using the relay with our ISP SMTP.
We want to send it directly. So Exchange -> EFA ->
So i'm trying to add EFA as a Send Connector in Exchange without success.
Justin
Post by Justin » 10 Jan 2019 12:36
Oke, so i got it working.
But on some emails i'm getting:
host mx.spamservice.nl[62.221.202.24] said: 451-xxx.xxx.xxx.xxx is not yet authorized to deliver mail from 451-<user1@mailbo1
x1.nl> to <user2@mailbox2.nl>. Please 451 try later. (in reply to RCPT TO command)
Post by henk » 16 Jan 2019 13:49
Did you configure the reverse DNS entries for the IP-addresses of your mailservers ? ( dig MX <<Domain>> | dig -x <<IP>>)
A great free tool to check a lot: https://mxtoolbox.com/
https://unix.stackexchange.com/question ... liver-mail
https://marekbosman.com/site/common-problems-with-mail/
