eFa4 Testing Status
Locked
eFa4 Testing Status
Post by shawniverson » 06 Jan 2019 14:17
Curent Testing Status
Last repo update: Tue Aug 20 21:30:40 UTC 2019
Current eFa 4.0.0 RPM release: 66
Current Version: eFa 4.0.0 RC3
Note: yum update and yum-cron active
Pending features
Fail2Ban
Current added features
Let's Encrypt
OpenDKIM and OpenDMARC (Reporting and Verification)
Automated recipient verification
Webmin option
Current known issues
Revisit signature line linking
eFa-Init recall needed
eFa-Init reboot prompt broken (CLI)
Extend clamd override timeout to 1800 from 900 (timeouts on slower installations from having to load signatures after restarts)
Resolved issues
eFa Init CLI passwords are now setting properly
CLI Configure spam submission via signature line removed
CLI Configure trusted networks removed
Post Init/MailWatch GUI -- Status message getting duplicated in footer during initialization
CLI Configure -- Gateway showing quotes on IP Settings
CLI Configure -- Setting recursion in IP Settings cannot reload unbound
CLI Init -- email not accepted as a web username
Post Init -- GTUBE not initializing bayes database
CLI Configure -- Spam Settings submenu not loading
CLI Configure -- Inline signature rules description needs changed
Spamassassin Lint -- Resolved loading of txrep and bayes databases under correct user (postfix)
CLI Configure -- Hosts not displaying after modification in outbound mail relay setting
Post Init -- Spamassassin rule descriptions not updating during post init
SALearn -- Use of uninitialized value in numeric gt (>) at /usr/share/perl5/vendor_perl/Mail/SpamAssassin/Plugin/TxRep.pm line 1468., Use of uninitialized value in string eq at /usr/share/perl5/vendor_perl/Mail/SpamAssassin/Plugin/TxRep.pm line 1505.,
CLI Configure -- System Restore not loading
msre_reload.sh -- removed
trim-awl -- not applicable, need a trim-txrep instead
Backup -- multiple cp operations failing
trim-txrep -- misconstructed and in wrong directory
Post Init -- Zombie process
trim-txrep -- ERROR 1054 (42S22) at line 1: Unknown column 'last_hit' in 'where clause'
Restore -- cp: cannot stat ‘/usr/eFa/backup/backup/usr/*’: No such file or directory
Restore -- ERROR 1045 (28000): Access denied for user 'mailwatch'@'localhost' (using password: NO)
Import -- Errors when restoring from another appliance backup
Import -- /etc/fstab not importable
Import -- Wrong order for MailScanner config merge
Import -- /etc/EFA-Config missing
Migration -- Access denied for user mailwatch at localhost for MySQL
Import -- Milter configuration missing
Import - Bayes database missing
Migration/Restore/Import -- Error: Database connection failed...
Migration -- mv: cannot stat '/et/MailScanner/reports.v4': No such file or directory
Migration -- ERROR: The "envelope_sender_header" in your spamassassin.conf 0.00352
Migration -- inline sig errors in MailScanner Lint
Migration -- config: failed to parse, now a plugin, skipping, in "/etc/mail/spamassassin/local.cf": ok_languages en
Migration -- bayes database blank
CLI Configure -- quotes appearing about ipv6 gateway
CLI Configure -- BOOTPROTO not being checked and updated
Post Init -- post init cannot restart if dead and lock file is present
CLI Configure -- cannot set/unset BOOTPROTO and IPV6_AUTOCONF
ipv6 + ipv4 -- post init stuck when ipv4 is operational but ipv6 is not routing properly
Post Init -- ...ERROR INITIALIZATING, CHECK INTERNET ACCESS GATEWAYS... (gateway is online and functional)
Post Init -- cat: /etc/sudoers.d/mailwatch: No such file or directory
clamd -- rpm update to clamd overwrites /usr/lib/tmpfiles.d/clamd.scan.conf, causing MailScanner to stop scanning email
ipv6 -- Setting ip address during GUI Init not taking effect
3rd party A/V...Known issue in MailScanner handling Sophos and AVG output
GUI Init -- The server returned a "500 Internal Server Error". during CLI Username entry
MTA Stats -- PHP Notice: Undefined offset: 1 in /usr/bin/mailwatch/tools/Postfix_relay/mailwatch_milter_relay.php on line 91
clamd -- clamd: LibClamAV Error: cli_loaddbdir(): No supported database files found in /var/lib/clamav
Dovecot -- dovecot[15512]: master: Error: service(auth): unlink(/var/spool/postfix/private/auth) failed: Is a directory
LXC Build -- Failed to execute operation: No such file or directory (twice)
LXC Init -- Error Configuring Interface
LXC Init -- Interface detection failing
LXC Init -- Error setting Timezone
LXC MailScanner Lint -- Can't run file command ("/usr/bin/file"): No such file or directory at /usr/share/MailScanner/perl/MailScanner/SweepOther.pm line 473.
MariaDB -- [Warning] Could not increase number of max_open_files to more than 1024 (request: 4182)
Milter -- Error in configuration file line 3142, directory /var/spool/MailScanner/incoming/Locks for lockfiledir does not exist (or is not readable) (happens when mailscanner is not running and incoming is a ramdisk...ignoring for now)
MailWatch -- PHP Warning: ini_set(): A session is active. You cannot change the session module's ini settings at this time in /var/www/html/mailscanner/logout.php on line 40, referer: https://xx.lan/mailscanner/sf_version.php (reported upstream)
GUI Init -- parts after first ':' not being filtered out in CLI Username validation check
Commit -- error Failed to reload mariadb.service: Job type reload is not applicable for unit mariadb.service.
CLI Configure -- Cannot alter hostname/domainname
MailWatch -- Menu wrapping around when h size is reduced
SELinux -- dovecot_t denials and dbus class denials
Postfix -- postmaster notifications defaulting to postmaster@example.org
Commit -- setting interface config when net.ifnames=0 kernel is set does not work
Autolearn -- ham is autolearning, but spam is not autolearning
Greylisting -- dbaccess errors in messages log
Commit: line 1036: /var/log/yum/yum/yum.log: No such file or directory
Apache -- [Sun Jan 20 16:40:09.250912 2019] [http2:warn] [pid 4001] AH10034: The mpm module (prefork.c) is not supported by mod_http2. The mpm determines how things are processed in your server. HTTP/2 has more demands in this regard and the currently selected mpm will just not do. This is an advisory warning. Your server will continue to work, but the HTTP/2 protocol will be inactive.
Cron -- still firing notifications to root@$domainname despite explicit setting in /etc/crontab
MTA Stats -- MTA stats crons are firing empty email alerts every hour to root@$domainname
Updates -- MailWatch update removed Greylist menu item
Updates -- Modifications to /etc/my.cnf.d/mariadb-server.cnf placing spaces in front of options during initial build and causing duplication during update
Apache -- smtp.example.org:443:0 server certificate is a CA certificate (BasicConstraints: CA == TRUE !?)
Apache -- smtp.example.org:443:0 server certificate does NOT include an ID which matches the server name
Greylist -- SQLGrey fails to start if it cannot bind to ::1 (when ipv6 is disabled due to preexisting environment sqlgrey cannot )
Greylisting -- service dependency needed for sqlgrey
Greylist -- PHP Notice: session_start(): A session had already been started - ignoring in /var/www/html/mailscanner/grey.php on line 4
Greylisting -- sqlgrey: Couldn't unlink "/var/run/sqlgrey.pid" [Permission denied]
MailWatch GUI -- clamav versions suddenly blank after latest update
LXC Updates -- anacrontab not present
MailScanner Lint -- Failing to run from GUI due to mpm module changes in apache
Postfix -- fix root mail delivery (using canonical maps instead)
MSMilter -- Service dependency for mailscanner service
Networking ... relocate interface backups somewhere else
clamd -- socket directory for clamd resets when clamd rpm updates, causing MailScanner to stop processing email
Updates -- amiguous as to cause of failure, and no logging
crond -- firing hourly email alerts for /usr/bin/php -q /usr/bin/mailwatch/tools/Postfix_relay/mailwatch_postfix_relay.php
clamav-unofficial -- /usr/lib/systemd/system/clamav-unofficial-sigs.service is marked executable. Please remove executable permission bits. Proceeding anyway
LXC Init -- timedatectl executing in lxc and throwing error
MailWatch GUI -- postfix version not displaying
MTA Stats -- Enable and start posfix_relay and milter_relay systemd units
Cron -- Could not get metalink https://mirrors.fedoraproject.org/metal ... rch=x86_64 error was
14: HTTPS Error 503 - Service Unavailable
msre-edit -- Backing up current file...ERROR: Could not make backup!
Postfix -- typo in master.cf causing issues -o smtpd_sasl_security_options=noanaonymous
MailScanner Lint -- cannot run\
GeoIP2 -- Updating GeoIP is failing due to incorrect owner/group (should be php-fpm instead of apache)
Apache -- Disabled module causing problems when httpd updates via yum
SELinux -- more denials during MailScanner --lint and causing performance delays
IPV6 -- option to use ipv4 only dns (was disable ipv6 completely....disabling ipv6 dns lookups may be sufficient to resolve ipv6 post init issue w/o major changes)
eFa-Init GUI -- 500 Internal Server Error at cliusername form
eFa-Init CLI -- Formatting problem on summary page
MySQL -- Remove root @ 127.0.0.1 and ::1 entries in database
eFa-Configure -- Cannot load IP Settings after update
eFa-Commit -- ifcfg-$inteface.bak present in wrong directory
eFa-Init CLI -- enable Ipv6 dns: only Y will continue
eFa-Init CLI -- Cosmetic issue on summary page
Postfix -- /etc/postfix/sender_canonical malformed
MariaDB -- CPU core stuck at 100% after update
IPV6DNS missing in /etc/eFa/eFa-Config after update
eFa-Configure -- not reading do-ip6 from unbound.conf properly
warning: database /etc/postfix/sender_canonical.db is older than source file /etc/postfix/sender_canonical
MailWatch -- Learn spam hanging
eFaInit GUI -- Opting not to set static IP addresses for both v4 and v6 leaves a blank URL to visit after rebooting
Postfix -- QMQP adding a localhost received header during processing
Spamassassin Lint -- dbg: config: mkdir /var/lib/php/fpm/.spamassassin failed: mkdir /var/lib/php/fpm/.spamassassin: Permission denied at /usr/share/perl5/vendor_perl/Mail/SpamAssassin.pm line 1900.
ms-update-sa triggering eFa Monitor alert
KAM false positives -- (8.0 score on Amazon Prime as KAM_FACEBOOKMAIL)
postfix/smtpd[24702]: warning: database /etc/postfix/recipient_canonical.db is older than source file /etc/postfix/recipient_canonical
sqlgrey errors after migrating and rebooting
error: failed to rmdir /var/spool/MailScanner/incoming/SpamAssassin-Temp/MSlintF9OvtO: Permission denied
/etc/cron.daily/trim-txrep: ERROR 1054 (42S22) at line 1: Unknown column 'last_hit' in 'where clause'
/root/.my.cnf not updated during a migration
ERROR 1071 (42000) at line 10: Specified key was too long: max key length is 767 bytes
efa crond[24538]: (root) BAD FILE MODE (/etc/cron.d/msre_reload)
Attributes wrong on /etc/eFa/openDMARC-Config
eFa-Monitor fired on mailscanner during cron.daily run
eFa-Monitor from address is the to address (self)
logrotate needed for /var/log/eFa/update.log
eFa-Configure -- DNS server entry throwing an error
HTTP -> HTTPS redirect not working
MS_FOUND_SPAMVIRUS header not organization specific
opendkim selinux denials
clamav daemon having trouble after initial unofficial sigs downloads during init phase
Warnings about sender and recipient canonical map dbs being out of date
Temp queue files appearing in milter and staying there
ntpd_t SELinux denials
1x1 spacer reverting to MailScanner instead of eFa Website
SELinux denials -- dhcpc_t
devbuild.sh updated IUS GPG key location to /etc/pki/rpm-gpg/RPM-GPG-KEY-IUS-7
/usr/sbin/eFa-Post-Init: line 144: /etc/cron.hourly/mailwatch_relay.sh: No such file or directory
Upstream fixes needed for MailScanner to be pulled into eFa
Name resolution for mariadb needs turned off
Let's Encrypt renewal not succeeding.
DCC server menu throwing errors
temp folder for /var/lib/mysql/temp vanished on a RC3 test instance (could not view Search and Reports pane)
Typo in eFa-Configure disable IPv6 menu
cyrus-sasl cyrus-sasl-lib cyrus-sasl-plain needed
certbot cron mangled
Maxed CPU core on mariadb after reboot and does not settle down until daemon restarted (run a db trace) -- just affecting one instance in my setup
clamd restart loop, suspect same issue causing mariadb issues timeouts for systemd need extended
clamd systemd unit timeout exceeded
Version eFa 4.0.1 now available!
Locked
