Setup SMTP relay
Alleyviper
Setup SMTP relay
Post by Alleyviper »
Hi there,
Currently I'm using EFA 3.0.2.6 as inbound filtering for multiple domains and Scrollout F1 for outbound, as it is easy to setup dkim and outbound relay.
I've been searching for the proper way to replicate outbound used on Scrollout F1 in Efa but is not been easy.
Has anyone done outbound setup and can give me and others a light on this?
Best regards,
Re: Setup SMTP relay
Justin
Post by Justin »
Could you guide me with setting up EFA as a smarthost/relay for Exchange?
For some reason i can't get it working.
Exchange servers are external, so not on the local network
