Sophos AV does no more work !
Post by nicola.piazzi »
I found that mailscanner doesn no more catch sophos virus, this in an existing installation and also in a fresh install
Here maillog of a working message :
2018-12-03T01:13:17.634913+01:00 EFA42 MailScanner[4191]: >>> Virus 'Mal/DrodAce-A' found in file ./27176108233.AC1B9/201283765ref20181203_xls.ace
2018-12-03T01:13:17.635238+01:00 EFA42 MailScanner[4191]: Virus Scanning: Sophos found 1 infections
2018-12-03T01:13:17.635417+01:00 EFA42 MailScanner[4191]: Infected message 27176108233.AC1B9 came from 82.193.37.22
2018-12-03T01:13:17.635543+01:00 EFA42 MailScanner[4191]: Virus Scanning: Found 1 viruses
Here maillog of a non working message :
2018-12-17T16:21:48.334526+01:00 EFA42 MailScanner[2649]: >>> Virus 'Mal/DrodAce-A' found in file /var/pool/MailScanner/incoming/2649/DB73A106051.A5516/nPO-18191111060.ace
2018-12-17T16:21:48.334859+01:00 EFA42 MailScanner[2649]: Virus Scanning: Sophos found 1 infections
2018-12-17T16:21:48.335071+01:00 EFA42 MailScanner[2649]: Infected message var came from
2018-12-17T16:21:48.335207+01:00 EFA42 MailScanner[2649]: Virus Scanning: Found 1 viruses
NOTE Infected message “var” instead real file name !!!
This is newest installed version
[root@EFA41 sbin]# sweep --version
SAVScan virus detection utility
Copyright (c) 1989-2018 Sophos Limited. All rights reserved.
System time 05:01:58 PM, System date 31 December 2018
Product version : 5.53.0
Engine version : 3.74.2
Virus data version : 5.58
User interface version : 2.03.074
Platform : Linux/AMD64
Released : 11 December 2018
Total viruses (with IDEs) : 28304428
Re: Sophos AV does no more work !
Something changed within Sophos. Mailscanner Lint shows a non-existing path :/var/pool/MailScanner/
Due the lack of virusmails I do not know how to check, besides the MailScanner lint check, but quite sure its related to the non-existing path
and different file name neicar.com versus eicar.com
On the todo list for next year 8-)
Old working version 20 Nov 2018
[root@xx var]#
MailScanner --lint --debug
Trying to setlogsock(unix)
blabla..
Version number in MailScanner.conf (5.0.7) is correct.
Your envelope_sender_header in spamassassin.conf is correct.
Using locktype = posix
MailScanner.conf says "Virus Scanners = clamd sophos"
Found these virus scanners installed: clamavmodule, sophos, clamd
Filename Checks: Windows/DOS Executable (1 eicar.com)
Other Checks: Found 1 problems
Clamd::INFECTED:: Eicar-Test-Signature :: ./1/eicar.com
Virus Scanning: Clamd found 1 infections
>>> Virus 'EICAR-AV-Test' found in file ./1/eicar.com
Infected message 1 came from 10.1.1.1
Virus Scanning: Found 2 viruses
Virus Scanner test reports:
Clamd said "eicar.com was infected: Eicar-Test-Signature"
Sophos said ">>> Virus 'EICAR-AV-Test' found in file ./1/eicar.com"
<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<new version>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>
[root@xx var]#
blabla..
>>> Virus 'EICAR-AV-Test' found in file /var/pool/MailScanner/incoming/11141/1/neicar.com
Check log
[root@xx ~]#
/opt/sophos-av/bin/savlog --today --utc |grep Threat
2018-12-31 18:07:30: log.threat Threat detected in /var/spool/MailScanner/incoming/11141/1/neicar.com: EICAR-AV-Test during on-demand scan. (The file is still infected.)
[root@xx var]#
sweep --version
System time 07:08:24 PM, System date 31 December 2018
Yes, but if you invoke a scan with new sophos output is correct (spool and not pool)
Also avg doesnt work
Hi henk
Also AVG have (same) problem
Install so :
yum install glibc.i686
wget http://download.avgfree.com/filedir/ins ... 6.i386.rpm
rpm -i avg2013flx-r3118-a6926.i386.rpm
vi /etc/MailScanner/virus.scanners.conf
avg /usr/lib/MailScanner/wrapper/avg-wrapper /usr <<<<<<< this little change
First MailScanner --lint WORKS OK
MailScanner.conf says "Virus Scanners = avg"
Found these virus scanners installed: avg, clamavmodule, sophos, clamd
Avg: Virus identified EICAR_Test in eicar.com
Virus Scanning: Avg found 1 infections
Avg said "Found virus EICAR_Test in file eicar.com"
If any of your virus scanners (avg,clamavmodule,sophos,clamd)
Then make an avgupdate and
Then MailScanner --lint KO
Avg: Virus identified EICAR_Test in neicar.com
Note the difference "Avg: Virus identified EICAR_Test in eicar.com" and "Avg: Virus identified EICAR_Test in >>>n<<<eicar.com"
neicar is same problem of sophos
Hi Nicola,
I would like to know if there a members with additional scanners ( besides Sophos and AVG) having the same issue.
As clamav is still working, there is no need to panic, but we need to solve this a.s.a.p.
Would Shawn like to comment on this?
MailScanner --version
Running on Linux 2.6.32-754.9.1.el6.x86_64 #1 SMP Thu Dec 6 08:02:15 UTC 2018 x86_64 x86_64 x86_64 GNU/Linux
This is CentOS release 6.10 (Final)
This is Perl version 5.010001 (5.10.1)
This is MailScanner version 5.0.7
Check:
As I miss the skills to determan the cause, a simple check on the mailscanner scripts somewhat reveals the special handling for Eicar tests:
Each scanner is handled separately:
grep -irHn 'EICAR'  /usr/lib/MailScanner/MailScanner/perl/MailScanner
SweepViruses.pm:1398: #>>> Virus 'EICAR-AV-Test' found in file /root/q/qeicar/eicar.com
SweepViruses.pm:1399: #>>> Virus 'EICAR-AV-Test' found in file /root/q/qeicar/eicar.doc
SweepViruses.pm:1400: #>>> Virus 'EICAR-AV-Test' found in file /root/q/qeicar/eicar.rar/eicar.com
SweepViruses.pm:1401: #>>> Virus 'EICAR-AV-Test' found in file /root/q/qeicar/eicar.rar3a/eicar.doc
SweepViruses.pm:1402: #>>> Virus 'EICAR-AV-Test' found in file /root/q/qeicar/eicar.rar3a/eicar.com
SweepViruses.pm:1403: #>>> Virus 'EICAR-AV-Test' found in file /root/q/qeicar/eicar.zip/eicar.com
SweepViruses.pm:1500: #./g4UFLJR23090/Keld Jrn Simonsen: Infected: EICAR_Test_File [F-Prot]
SweepViruses.pm:1501: #./g4UFLJR23090/Keld Jrn Simonsen: Infected: EICAR-Test-File [AVP]
SweepViruses.pm:1504: #./eicar.com: Infected: EICAR_Test_File [Libra]
SweepViruses.pm:1505: #./eicar.com: Infected: EICAR Test File [Orion]
SweepViruses.pm:1506: #./eicar.com: Infected: EICAR-Test-File [AVP]
SweepViruses.pm:1507: #./eicar.doc: Infected: EICAR_Test_File [Libra]
SweepViruses.pm:1508: #./eicar.doc: Infected: EICAR Test File [Orion]
SweepViruses.pm:1509: #./eicar.doc: Infected: EICAR-Test-File [AVP]
SweepViruses.pm:1510: #[./eicar.zip] eicar.com: Infected: EICAR_Test_File [Libra]
SweepViruses.pm:1511: #[./eicar.zip] eicar.com: Infected: EICAR Test File [Orion]
SweepViruses.pm:1512: #[./eicar.zip] eicar.com: Infected: EICAR-Test-File [AVP]
SweepViruses.pm:1620: #(Real infected archive: /var/spool/MailScanner/incoming/19746/./i75EFmSZ014248/eicar.rar)
SweepViruses.pm:1743: #./1B978O-0000g2-Iq/eicar.com Virus identified EICAR_Test (+2)
SweepViruses.pm:1744: #./1B978O-0000g2-Iq/eicar.zip:\eicar.com Virus identified EICAR_Test (+2)
Message.pm:4595: # contained a virus (e.g. the text of EICAR) without any proper
MessageBatch.pm:79: # Fake a batch containing the Eicar message
MessageBatch.pm:81: $this->CreateEicarBatch();
MessageBatch.pm:1200:sub CreateEicarBatch {
MessageBatch.pm:1203: #print STDERR "Creating EICAR batch\n";
MessageBatch.pm:1232: 'Content-Type: application/octet-stream; name="eicar.com"',
MessageBatch.pm:1234:'Content-Disposition: attachment; filename="eicar.com"'
MessageBatch.pm:1248: # This is a Base64-encoded, then ROT13-encoded copy of the EICAR test string.
MessageBatch.pm:1250: my $eicarstring = "JQICVINyDRSDJmEpHScLAGDbHS4cA0AQXGq9WRIWD0SFYIAHDH5RDIWRYHSBIRyJFIWIHl1HEIAH\nYHMWGRHuWRteFPb=\n";
MessageBatch.pm:1251: $eicarstring =~ tr[a-zA-Z][n-za-mN-ZA-M]; # Undo ROT13 encoding
MessageBatch.pm:1252: print $fh $eicarstring;
ConfigDefs.pl:668:NoisyViruses Joke/ OF97/ WM97/ W97M/ eicar
Hi Henk,
I also use esets and it works well
Did some tests to determan the source.
Check if sophos returns correct path/filename
/usr/lib/MailScanner/wrapper/sophos-wrapper /opt/sophos-av /tmp  -all
Quick Scanning
>>> Virus 'EICAR-AV-Test' found in file /tmp/eicar.com.txt
21 files scanned in 10 seconds.
1 virus was discovered.
1 file out of 21 was infected.
If you need further advice regarding any detections please visit our
Threat Center at: http://www.sophos.com/en-us/threat-center.aspx
End of Scan.
same for mailscanner lint and check log
/opt/sophos-av/bin/savlog --today --utc |grep neicar
2019-01-03 13:33:08: log.threat Threat detected in /var/spool/MailScanner/incoming/30245/1/neicar.com: EICAR-AV-Test during on-demand scan. (The file is still infected.)
Now debug MailScanner
/usr/lib/MailScanner/MailScanner/perl/MailScanner/SweepViruses.pm
  1385 sub ProcessSophosOutput {
   1386   my($line, $infections, $types, $BaseDir, $Name) = @_;
   1387   my($report, $infected, $dot, $id, $part, @rest, $error);
   1388   my($logout);
   1389
   1390   print "$line";                <<<<<<     uncomment to print initial value
Results in correct path/filenamefile
>>> Virus 'EICAR-AV-Test' found in file /var/spool/MailScanner/incoming/1268/1/neicar.com
>>> Virus 'EICAR-AV-Test' found in file /var/pool/MailScanner/incoming/1268/1/neicar.com
Can someone step in? :think:
Do we need to file a bug for Mailscanner? :?:
The fun is, nothing changed in mailscanner code since nov 2018. :doh:
zcat yum.log-20190101.gz
Dec 11 11:32:00 Updated: php-json-7.2.13-2.el6.remi.x86_64
Dec 11 11:32:01 Updated: php-common-7.2.13-2.el6.remi.x86_64
Dec 11 11:32:01 Updated: munin-common-2.0.43-1.el6.noarch
Dec 11 11:32:02 Updated: munin-node-2.0.43-1.el6.noarch
Dec 11 11:32:02 Updated: munin-apache-2.0.43-1.el6.noarch
Dec 11 11:32:02 Updated: munin-2.0.43-1.el6.noarch
Dec 11 11:32:03 Updated: php-cli-7.2.13-2.el6.remi.x86_64
Dec 11 11:32:03 Updated: php-pdo-7.2.13-2.el6.remi.x86_64
Dec 11 11:32:09 Updated: kernel-firmware-2.6.32-754.9.1.el6.noarch
Dec 11 11:32:18 Installed: kernel-2.6.32-754.9.1.el6.x86_64
Dec 11 11:32:19 Updated: php-mysqlnd-7.2.13-2.el6.remi.x86_64
Dec 11 11:32:19 Updated: php-7.2.13-2.el6.remi.x86_64
Dec 11 11:32:20 Updated: php-xml-7.2.13-2.el6.remi.x86_64
Dec 11 11:32:20 Updated: php-gd-7.2.13-2.el6.remi.x86_64
Dec 11 11:32:20 Updated: php-mbstring-7.2.13-2.el6.remi.x86_64
Dec 11 11:32:20 Updated: php-ldap-7.2.13-2.el6.remi.x86_64
Dec 11 11:32:29 Installed: kernel-devel-2.6.32-754.9.1.el6.x86_64
Dec 11 11:32:31 Updated: ghostscript-8.70-24.el6_10.2.x86_64
Dec 11 11:32:32 Updated: kernel-headers-2.6.32-754.9.1.el6.x86_64
Dec 11 11:37:23 Erased: kernel
Dec 11 11:37:28 Erased: kernel-devel
Dec 18 20:09:26 Installed: perl-WWW-Curl-4.09-4.el6.x86_64
Dec 18 20:09:26 Installed: openssl-perl-1.0.1e-57.el6.x86_64
Dec 22 10:42:56 Updated: ntpdate-4.2.6p5-15.el6.centos.x86_64
Dec 22 10:42:57 Updated: ntp-4.2.6p5-15.el6.centos.x86_64
Dec 22 10:42:57 Updated: remi-release-6.10-1.el6.remi.noarch
Dec 30 21:48:50 Installed: tuned-0.2.19-18.el6.noarch
gregecslo
Post by gregecslo »
Hi!
Same here.
ClamD works
Esets works
Sophos fails to report and lint is not listing it.
thewomble
Post by thewomble »
I just done a mailscanner lint test and I got email notification, thinking about I not seem a Sophos notification in a while apart from EICAR test just done.
A threat was detected during an on-demand scan. Details follow:
2 files scanned.
Number of infections detected: 1
Number of infected files detected: 1
/var/spool/MailScanner/incoming/1063/1/neicar.com is infected with EICAR-AV-Test.
For one reason or another, I not upgraded to 3.0.2.6, running 3.0.2.5 and I running ClamD version 0.99
Total viruses (with IDEs) :	28305100
ClamAV Status
Version:	ClamAV 0.99.2
Virus Identities:	25298
Database Timestamp:	Mon Jan 14 18:19:36 2019
Not sure if that helps, if you want to another test let me know.
Working on this...hope to have an answer soon...
gregecslo
Post by gregecslo »
Yes PLEASE :)
I can cook you a coffee or 2 :)
Besides lots of coffee :) , until there is an answer, it makes sense to temp disable Sophos and the rule that generates the looping messages viewtopic.php?t=3304
--- /etc/MailScanner/conf.d/01_MailScanner.conf
 #Notices To = postmaster@private.lan
 #Local Postmaster = postmaster@private.lan
-Virus Scanners = clamd sophos
+Virus Scanners = clamd
--- /etc/mail/spamassassin/local.cf
 #   Add *****SPAM***** to the Subject header of spam e-mails
 # rewrite_header Subject *****SPAM*****
+meta __E_LIKE_LETTER (0)
+meta __LOWER_E (0)
gregecslo
Post by gregecslo »
Ummm I don`t have looping messages.
Version?
MailWatch- MailScanner-Version-information.png (16.51 KiB) Viewed 40367 times
gregecslo
Post by gregecslo »
MailWatch for MailScanner v1.2.7-dev running on EFA-3.0.2.6
Clamav: Version: ClamAV 0.100.2
MS: 5.0.7
SpamAssassin version 3.4.1
Postfix 3.1.3
Refactored (one liner fix):
https://github.com/MailScanner/v5/pull/353
gregecslo
Post by gregecslo »
Hi!
After AVG fix:
Reloading MailScanner ...
Global symbol "$id" requires explicit package name at /usr/share/MailScanner/perl/MailScanner/SweepViruses.pm line 1812.
Global symbol "$id" requires explicit package name at /usr/share/MailScanner/perl/MailScanner/SweepViruses.pm line 1813.
Global symbol "$part" requires explicit package name at /usr/share/MailScanner/perl/MailScanner/SweepViruses.pm line 1815.
Global symbol "$part" requires explicit package name at /usr/share/MailScanner/perl/MailScanner/SweepViruses.pm line 1816.
Global symbol "$part" requires explicit package name at /usr/share/MailScanner/perl/MailScanner/SweepViruses.pm line 1817.
Global symbol "$part" requires explicit package name at /usr/share/MailScanner/perl/MailScanner/SweepViruses.pm line 1818.
Global symbol "$part" requires explicit package name at /usr/share/MailScanner/perl/MailScanner/SweepViruses.pm line 1819.
Global symbol "$part" requires explicit package name at /usr/share/MailScanner/perl/MailScanner/SweepViruses.pm line 1820.
Global symbol "$part" requires explicit package name at /usr/share/MailScanner/perl/MailScanner/SweepViruses.pm line 1822.
Global symbol "$notype" requires explicit package name at /usr/share/MailScanner/perl/MailScanner/SweepViruses.pm line 1830.
Global symbol "$id" requires explicit package name at /usr/share/MailScanner/perl/MailScanner/SweepViruses.pm line 1833.
Global symbol "$part" requires explicit package name at /usr/share/MailScanner/perl/MailScanner/SweepViruses.pm line 1833.
Global symbol "$id" requires explicit package name at /usr/share/MailScanner/perl/MailScanner/SweepViruses.pm line 1834.
Global symbol "$part" requires explicit package name at /usr/share/MailScanner/perl/MailScanner/SweepViruses.pm line 1834.
BEGIN not safe after errors--compilation aborted at /usr/share/MailScanner/perl/MailScanner/SweepViruses.pm line 1840.
Compilation failed in require at /usr/sbin/MailScanner line 106.
BEGIN failed--compilation aborted at /usr/sbin/MailScanner line 106.
I have:
my $virus = $line;
  $virus =~ s/^.+\s+(.+?)$/$1/;
  #print STDERR "Line: $line\n";
  #print STDERR "virus = \"$virus\"\n";
  my $logout = $line;
        ## BEGIN
        # Full message scanning fix
        # https://github.com/MailScanner/v5/issues/348
        if ( $logout !~ /message[:\s].*(?:virus|trojan)/ ) {
    $logout =~ s/\s{2,}/ /gs;
    $logout =~ s/:./->/;
    # Change all the spaces into / for the split coming up
    # Also the second variant prepends the archive name to the
    # infected filename with a:\ so we need to change that to
    # something else. I chose another / so it would end up in the
    # @rest wich is also why I changed the \s+ to /
    # then Remove path elements before /./ leaving just id/part/rest
    $line =~ s/\s+/\//g;
    $line =~ s/:\\/\//g;
    $line =~ s/:\//\//g; # JKF AVG8 :/ separates archives now too.
    $line =~ s/\.\///;
    my($id, $part, @rest) = split(/\//, $line);
    $part =~ s/\t.*$//;
    $part =~ s/=\>.*$//;
    #print STDERR "id:$id:part = $part\n";
    #print STDERR "$Name : Found virus $virus in file $part ID:$id\n";
    # If avg finds both the archive and file to be infected and the file
    # exists in more than one (because of SafeName) archive the archive is
    # reported twice so check and make sure the archive is only reported once
    my $notype = substr($part,1);
    $logout =~ s/\Q$part\E/$notype/;
    $logout =~ /^.+\/(.+?)\s+(.+)\s*$/;
    MailScanner::Log::InfoLog("Avg: %s in %s", $2,$1);
  } else {
    # Parse ./id.message:/eicar.com Virus identified EICAR_Test
    # Parse ./id.message Virus identified EICAR_Test
	$line =~ s/\.\///;
    $id = $line;
    $id =~ s/^(.*)\.message.*$/$1/;
    $part = $line;
    $part =~ s/^.*\.message//;
    $part =~ s/^:\///;
    $part =~ s/\s.*$//;
    if ( $part eq "" ) {
      $part = "message";
      $logout =~ /^.+message\s+(.+)\s*$/;
      MailScanner::Log::InfoLog("Avg: %s in %s", $1,$part);
    } else {
  my $Report = $Name . ': ' if $Name;
  $Report .= "Found virus $virus in file $notype";
  my $ReportPattern = quotemeta($Report);
  $infections->{$id}{$part} .= "$Report\n" unless $infections->{$id}{$part} =~ /$ReportPattern/s;
  $types->{$id}{$part} .= "v" unless $types->{$id}{$part}; # so we know what to tell sender
  return 1;
Am I missing something?
This is NOT Avg fix but Sophos fix
And work well !
gregecslo
Post by gregecslo »
Umm no.
This is AVG fix what I posted.
I applied sophos fix and sophos works OK.
gregecslo
Post by gregecslo »
Thanks for the one-liner fix :clap:
Completely off topic, but as the one-liner remark activated some presumed lost memory braincells, it's quite strange you can trigger a long term memory restore in just a split second, without any backup... :doh:
For those who love the early days of computing and powerfull oneliners (Nibble Magazine 1980-1992, One-Liner and Two-Liner programs), it's still available, thanks to Sam Stoddard. http://www.nibblemagazine.com/nibble_disks.htm
