EFA 0.3 update released!
Important news
Locked
darky83
Site Admin
Post by darky83 »
The upgrade to EFA 0.3 is available:
  • Baruwa upgraded to 1.1.2.
  • Postfix mydestination was not updated during configuration.
  • EFA-Update in 0.2 was the wrong version, correct version added to 0.3 (Manual update will be needed from 0.2 to 0.3)
  • EFA-Configure is moved to EFA-Init (to be run once for initial config)
  • apt-get questions pre-answered during install.
  • New EFA-Configure script to modify the system after initial config and to configure new features.
  • - Option to change IP
  • - Option to change hostname
  • - Option to enable relaying for specific hosts (internal LAN for example)
  • - Option to enable outgoing smarthost
  • - Option to change admin email adres
  • - Option to change baruwa' s quarantine host report URL.
EFA 0.3 can be downloaded from the download page: http://www.efa-project.org/download/
Howto Upgrade
Sadly due to a bug in the 0.2 update script a manual update is needed.
First login as root on the console of your EFA machine and than run the following:
cd /var/EFA/update/
rm EFA-update-script
wget -q http://www.efa-project.org/update/EFA-update-script
chmod 700 EFA-update-script
/var/EFA/update/EFA-update-script
Note: You may need to reboot your machine manually a second time after the update is completed, watch your console for any errors.
Locked
