issues after 3.0.2.6 update
Posted: 29 Nov 2018 05:52
just installed vm image for 3.0.2.5 ran updates to 3.0.2.6 mail stopped flowing, fixed issues with clamav and vmwaretools, mail flowed again.
now i cannot login to webinterface i have reset password using EFA-Configure and i can login locally using my root and admin passwords, but still not via the web interface and now email has stopped flowing
/var/log/maillog:
Nov 28 21:36:52 mail postfix/smtpd[4488]: connect from mail-oln040092002023.outbound.protection.outlook.com[40.92.2.23]
Nov 28 21:36:52 mail postfix/smtpd[4488]: Anonymous TLS connection established from mail-oln040092002023.outbound.protection.outlook.com[40.92.2.23]: TLSv1.2 with cipher ECDHE-RSA-AES256-SHA384 (256/256 bits)
Nov 28 21:36:53 mail postfix/smtpd[4488]: NOQUEUE: reject: RCPT from mail-oln040092002023.outbound.protection.outlook.com[40.92.2.23]: 454 4.7.1 <rcastillo@cityofmontclair.org>: Relay access denied; from=<mastermind16@hotmail.com> to=<rcastillo@cityofmontclair.org> proto=ESMTP helo=<NAM01-SN1-obe.outbound.protection.outlook.com>
Nov 28 21:36:53 mail postfix/smtpd[4488]: disconnect from mail-oln040092002023.outbound.protection.outlook.com[40.92.2.23] ehlo=2 starttls=1 mail=1 rcpt=0/1 quit=1 commands=5/6
Nov 28 21:40:13 mail postfix/anvil[4490]: statistics: max connection rate 1/60s for (smtp:40.92.2.23) at Nov 28 21:36:52
Nov 28 21:40:13 mail postfix/anvil[4490]: statistics: max connection count 1 for (smtp:40.92.2.23) at Nov 28 21:36:52
Nov 28 21:40:13 mail postfix/anvil[4490]: statistics: max cache size 1 at Nov 28 21:36:52
Nov 28 21:41:20 mail postfix/postfix-script[6359]: stopping the Postfix mail system
any ideas? I have since switched back to my old email filter and will revisit this again tomorrow. Since this is a new install should i just start over again? Thanks for the help.
/var/log/maillog:
