Defective entries in phishing.bad.sites.conf
Posted: 08 Nov 2018 11:11
I noticed that eFa does not use the default MailScanner phishing.bad.sites.conf and phishing.safe.sites.conf.
That itself is not a problem but the phishing.bad.sites.conf has invalid or not working entries.
Most of the entries go like this:
But some have ",http:" attached:
This seems to make the entry invalid as the definitive fraud is not correctly marked as such.
It is only marked as possible fraud, but when it is in this file it should be definitive.
Even the current online file has these faults: http://dl.efa-project.org/MailScanner/p ... sites.conf
For now I fixed the issue in rewriting the EFA-MA-Update script and adding:
But I think it would be better to fix this on the server-side.
Thanks and regards
bad.url.comCode: Select all
bad.url.com,http:It is only marked as possible fraud, but when it is in this file it should be definitive.
sed -i 's/,http://g' phishing.bad.sites.confThanks and regards
