Hi All,
since last yum update I'm not able to login to mailscanner with my admin account.
Even resetting it on the console does not work.
does anyone have any clue?
Admin user pw reset does not work
Re: Admin user pw reset does not work
Resetting it Through webmin also not works
does anyone can point me in the right direction?
You can try resetting it in the database...
Look in /etc/EFA-Config for the mysql root password, log into the database, and alter the users table in mailscanner (mailwatch).
Hi Shawniverson,
found the root password en logged in to the SQL server, in the table "users" there's no user mailwatch to alter.
try this:
mysql
use mailscanner;
select username from users;
What do you get?
mysql
use mailscanner;
What do you get?
