Hello guys,
tonight my EFA blocked all emails with this error:
MailScanner: Message attempted to kill MailScanner
I solved the error, clamAV related: but now i want to process again all the blocked emails to deliver the legimit ones.
How can i do it? There are thousands of email, cant do it manually via web interface ..
Thank you in advance
[URGENT] Requeue (process again) all the email blocked in the last 12 hours
Re: [URGENT] Requeue (process again) all the email blocked in the last 12 hours
You will need to use a script to accomplish this. The process..
1) Gather all messages and place in a directory
2) Use a script to iterate through the files, extract the original recipient address, and call /usr/sbin/sendmail to requeue the message.
#!/bin/bash
pathname='/path/to/files/'
for filename in $pathname; do
if [[ -f "$filename" ]]; then
# extract orig recip
recip=$(grep "^[[:space:]]*for" $pathname$filename | head -n1 | awk '{print $2}' | sed 's/^<//' | sed 's/>$//' | sed 's/>;$//')
if [[ -n "$recip" ]]; then
sendmail -G -i $recip < $pathname$filename
fi
fi
done
i got the same situation, needed to resend incoming mails ( which where at the quarantine folders) to the local mail server.
The script was above was'nt working, i used this script:
pathname='/var/spool/MailScanner/quarantine/20181103/nonspam'
for filename in "$pathname"/*
do
/usr/sbin/sendmail.postfix -t < "$filename"
done
it should be adopted ( sendmail.postfix is different to sendmail) and it would be great to have a menu point somewhere to just select the date to resend emails from the nonspam folders to the internal users.
do
done
Don't know if v4 breaks the script or what. Here is what I did to get it working. Improvements would be welcome.
Left debug in there in case someboby needs it.
#!/bin/bash
#trap "set +x; sleep 1 ; set -x" DEBUG
filecount=0
pathname="/root/quarentine/*" # Path to directory
#echo "$pathname" # debug
#ls $pathname # debug
#echo "file name $filename" # debug
if [[ -e $(eval echo $filename) ]]; then
filecount=$[ $filecount +1 ]
recip=$(grep "^[[:space:]]*for" $filename | head -n1 | awk '{print $2}' | sed 's/^<//' | sed 's/>$//' | sed 's/>;$//')
#echo "$recip" # debug
#echo "$pathname$filename" # debug
sendmail -G -i $recip < $filename
fi
fi
echo "Prosessed $filecount files"
done
