Hi there,
I used "yum update" on one of our EFA systems.
Since it updated, customers are complaining they do not receive all emails they should be getting.
Releasing emails from the GUI also gives me errors:
Release: error code 75 returned from Sendmail: sendmail: fatal: ****@****(48): Recipient addresses must be specified on the command line or via the -t option postdrop: warning: stdin: unexpected EOF in data, record type 78 length 76 postdrop: fatal: uid=48: malformed input
(****@**** due too privacy)
Anyone else facing these issues?
Sending the exact same email to a gmail address does arrive.
Wierdest part is, some people do receive the emails but i cannot find them back in /var/log/maillog/
Kind regards,
Justin
mail issues after update
Re: mail issues after update
take a look at viewtopic.php?&t=3010
it will solve this issue to I quess.
Howto to search this forum: viewtopic.php?t=2974
I know how to searchhenk wrote: ↑24 Jul 2018 13:40take a look at viewtopic.php?&t=3010
Thankfully you helped me out on the other topic too.
