So I decided to try to upgrade EFA from 3.0.0.8... It's not going well and to be honest I'm not even sure where to begin troubleshooting this. Here is the output from the attempt. Any direction on this would be appriciated.
Thanks...
[user@efa ~]$ sudo /usr/local/sbin/EFA-Update -check
[sudo] password for user:
[EFA] Getting latest version number from http://dl.efa-project.org
[EFA] You are running EFA version EFA-3.0.0.8
[EFA] Latest version update is EFA-3.0.2.6
[user@efa ~]$ sudo /usr/local/sbin/EFA-Update -update
[EFA] Good you are root
[EFA] Starting update to EFA-3.0.2.6
Setting up Update Process
* base: mirror.gpmidi.net
* epel: mirror.steadfast.net
* extras: mirror.gpmidi.net
* rpmforge: mirror.us.leaseweb.net
* updates: mirror.gpmidi.net
http://apt.sw.be/redhat/el6/en/x86_64/d ... repomd.xml: [Errno 14] PYCURL ERROR 6 - "Couldn't resolve host 'apt.sw.be'"
Trying other mirror.
Resolving Dependencies
There are unfinished transactions remaining. You might consider running yum-complete-transaction first to finish them.
--> Running transaction check
---> Package abrt-addon-kerneloops.x86_64 0:2.0.8-40.el6.centos will be updated
---> Package abrt-addon-kerneloops.x86_64 0:2.0.8-43.el6.centos will be updated
---> Package abrt-addon-kerneloops.x86_64 0:2.0.8-44.el6.centos will be an update
--> Processing Dependency: abrt-libs = 2.0.8-44.el6.centos for package: abrt-addon-kerneloops-2.0.8-44.el6.centos.x86_64
--> Processing Dependency: abrt = 2.0.8-44.el6.centos for package: abrt-addon-kerneloops-2.0.8-44.el6.centos.x86_64
---> Package kernel.x86_64 0:2.6.32-754.2.1.el6 will be installed
---> Package kernel-devel.x86_64 0:2.6.32-754.2.1.el6 will be installed
---> Package kernel-firmware.noarch 0:2.6.32-642.15.1.el6 will be updated
---> Package kernel-firmware.noarch 0:2.6.32-696.el6 will be updated
---> Package kernel-firmware.noarch 0:2.6.32-696.1.1.el6 will be updated
---> Package kernel-firmware.noarch 0:2.6.32-754.2.1.el6 will be an update
---> Package kernel-headers.x86_64 0:2.6.32-642.15.1.el6 will be updated
---> Package kernel-headers.x86_64 0:2.6.32-696.1.1.el6 will be updated
---> Package kernel-headers.x86_64 0:2.6.32-754.2.1.el6 will be an update
---> Package abrt.x86_64 0:2.0.8-40.el6.centos will be updated
--> Processing Dependency: abrt = 2.0.8-40.el6.centos for package: abrt-addon-ccpp-2.0.8-40.el6.centos.x86_64
--> Processing Dependency: abrt = 2.0.8-40.el6.centos for package: abrt-cli-2.0.8-40.el6.centos.x86_64
--> Processing Dependency: abrt = 2.0.8-40.el6.centos for package: abrt-python-2.0.8-40.el6.centos.x86_64
--> Processing Dependency: abrt = 2.0.8-40.el6.centos for package: abrt-addon-python-2.0.8-40.el6.centos.x86_64
---> Package abrt.x86_64 0:2.0.8-44.el6.centos will be an update
--> Processing Dependency: abrt-python = 2.0.8-44.el6.centos for package: abrt-2.0.8-44.el6.centos.x86_64
---> Package abrt-libs.x86_64 0:2.0.8-40.el6.centos will be updated
--> Processing Dependency: abrt-libs = 2.0.8-40.el6.centos for package: abrt-addon-ccpp-2.0.8-40.el6.centos.x86_64
--> Processing Dependency: abrt-libs = 2.0.8-40.el6.centos for package: abrt-tui-2.0.8-40.el6.centos.x86_64
---> Package abrt-libs.x86_64 0:2.0.8-43.el6.centos will be updated
--> Processing Dependency: abrt-libs = 2.0.8-43.el6.centos for package: abrt-addon-ccpp-2.0.8-43.el6.centos.x86_64
---> Package abrt-libs.x86_64 0:2.0.8-44.el6.centos will be an update
---> Package abrt-addon-ccpp.x86_64 0:2.0.8-40.el6.centos will be updated
---> Package abrt-addon-ccpp.x86_64 0:2.0.8-43.el6.centos will be updated
---> Package abrt-addon-ccpp.x86_64 0:2.0.8-44.el6.centos will be an update
---> Package abrt-python.x86_64 0:2.0.8-40.el6.centos will be updated
---> Package abrt-python.x86_64 0:2.0.8-43.el6.centos will be updated
---> Package abrt-python.x86_64 0:2.0.8-44.el6.centos will be an update
---> Package abrt-tui.x86_64 0:2.0.8-40.el6.centos will be updated
---> Package abrt-tui.x86_64 0:2.0.8-44.el6.centos will be an update
---> Package kernel.x86_64 0:2.6.32-642.6.1.el6 will be erased
---> Package kernel.x86_64 0:2.6.32-642.6.2.el6 will be erased
---> Package kernel-devel.x86_64 0:2.6.32-642.6.1.el6 will be erased
---> Package kernel-devel.x86_64 0:2.6.32-642.6.2.el6 will be erased
Error: Package: abrt-cli-2.0.8-40.el6.centos.x86_64 (@base)
Requires: abrt = 2.0.8-40.el6.centos
Removing: abrt-2.0.8-40.el6.centos.x86_64 (@base)
Updated By: abrt-2.0.8-44.el6.centos.x86_64 (base)
Error: Package: abrt-addon-python-2.0.8-40.el6.centos.x86_64 (@base)
** Found 20 pre-existing rpmdb problem(s), 'yum check' output follows:
abrt-addon-ccpp-2.0.8-43.el6.centos.x86_64 is a duplicate with abrt-addon-ccpp-2.0.8-40.el6.centos.x86_64
abrt-addon-ccpp-2.0.8-43.el6.centos.x86_64 has missing requires of abrt = ('0', '2.0.8', '43.el6.centos')
abrt-addon-kerneloops-2.0.8-43.el6.centos.x86_64 is a duplicate with abrt-addon-kerneloops-2.0.8-40.el6.centos.x86_64
abrt-addon-kerneloops-2.0.8-43.el6.centos.x86_64 has missing requires of abrt = ('0', '2.0.8', '43.el6.centos')
abrt-addon-python-2.0.8-43.el6.centos.x86_64 is a duplicate with abrt-addon-python-2.0.8-40.el6.centos.x86_64
abrt-addon-python-2.0.8-43.el6.centos.x86_64 has missing requires of abrt = ('0', '2.0.8', '43.el6.centos')
abrt-cli-2.0.8-43.el6.centos.x86_64 is a duplicate with abrt-cli-2.0.8-40.el6.centos.x86_64
abrt-cli-2.0.8-43.el6.centos.x86_64 has missing requires of abrt = ('0', '2.0.8', '43.el6.centos')
abrt-libs-2.0.8-43.el6.centos.x86_64 is a duplicate with abrt-libs-2.0.8-40.el6.centos.x86_64
abrt-python-2.0.8-43.el6.centos.x86_64 is a duplicate with abrt-python-2.0.8-40.el6.centos.x86_64
abrt-python-2.0.8-43.el6.centos.x86_64 has missing requires of abrt = ('0', '2.0.8', '43.el6.centos')
kernel-firmware-2.6.32-696.el6.noarch is a duplicate with kernel-firmware-2.6.32-642.15.1.el6.noarch
kernel-firmware-2.6.32-696.1.1.el6.noarch is a duplicate with kernel-firmware-2.6.32-696.el6.noarch
kernel-headers-2.6.32-696.1.1.el6.x86_64 is a duplicate with kernel-headers-2.6.32-642.15.1.el6.x86_64
libreport-2.0.9-33.el6.centos.x86_64 is a duplicate with libreport-2.0.9-32.el6.centos.x86_64
libreport-compat-2.0.9-33.el6.centos.x86_64 is a duplicate with libreport-compat-2.0.9-32.el6.centos.x86_64
libreport-filesystem-2.0.9-33.el6.centos.x86_64 is a duplicate with libreport-filesystem-2.0.9-32.el6.centos.x86_64
libreport-plugin-reportuploader-2.0.9-33.el6.centos.x86_64 is a duplicate with libreport-plugin-reportuploader-2.0.9-32.el6.centos.x86_64
libreport-plugin-rhtsupport-2.0.9-33.el6.centos.x86_64 is a duplicate with libreport-plugin-rhtsupport-2.0.9-32.el6.centos.x86_64
libreport-python-2.0.9-33.el6.centos.x86_64 is a duplicate with libreport-python-2.0.9-32.el6.centos.x86_64
Update to Version 3.0.0.9 FAILED. Updates cancelled.
Please visit https://www.efa-project.org for more information.
Upgrading from 3.0.0.8
Re: Upgrading from 3.0.0.8
you did try as mentioned in the log?
Upgrading from 3008......
yum-complete-transactionUpgrading from 3008......
I somehow totally missed that. I thought maybe the issue was CentOS looking for older repositories and would have to remove/replace them somehow. I'll give that a try though thanks.henk wrote: 24 Jul 2018 13:48 you did tryas mentioned in the log?Code: Select all
