Clamd update kills my EFA
General E.F.A. discussion
jamerson
Post by jamerson » 13 Jul 2018 08:33
Hi guys,
after the last update of the antivirus CLAMD my EFA keeps detecting everything as spam.
Clamd::ERROR:: COULD NOT CONNECT TO CLAMD, RECOMMEND RESTARTING DAEMON :: .
Jul 13 10:20:42 filter MailScanner[3045]: Virus Scanning: Clamd found 1 infections
Jul 13 10:20:42 filter MailScanner[3045]: Virus Scanning: No virus scanners worked, so message batch was abandoned and retried!
alle emails are infected according to the CLAM. to release the emails we had to reboot the EFA otherwise they are not deleverd.
when i log to the web gui i can see the emails there but to release them is only reboot the EFA.
E-mail Preambulen
Subject: Cron <clam@filter> [ -x /usr/bin/clamav-unofficial-sigs.sh ] && /bin/bash /usr/bin/clamav-unofficial-sigs.sh > /dev/null
Content-Type: text/plain; charset=UTF-8
Auto-Submitted: auto-generated
X-Cron-Env: <LANG=en_US.UTF-8>
X-Cron-Env: <SHELL=/bin/sh>
X-Cron-Env: <HOME=/var/lib/clamav>
X-Cron-Env: <PATH=/usr/bin:/bin>
X-Cron-Env: <LOGNAME=clam>
X-Cron-Env: <USER=clam>
[root@filter admin]# service clamd start
LibClamAV Warning: cli_loadyara: failed to parse or load 7 yara rules from file /var/lib/clamav/antidebug_antivm.yar, successfully loaded 92 rules.
LibClamAV Warning: Detected duplicate databases /var/lib/clamav/main.cvd and /var/lib/clamav/main.cld, please manually remove one of them
The Solutions is :
Thanks to Spammy,
the solution is
 /etc/clamav-unofficial-sigs/master.conf
 yararulesproject_enabled="no"
 enable_yararules="no"
delete *.yar and *.yara from /var/lib/clamav/
command to delete and restart the service
sudo rm /var/lib/clamav/*yar
sudo rm /var/lib/clamav/*yara
sudo service clamd start
jamerson
Re: Clamd update kills my EFA
Post by jamerson » 13 Jul 2018 08:51
See above the solution.
if you have any questions let me know
bikertrash
Post by bikertrash » 13 Jul 2018 10:57
Thank you for this... looks like it did the trick for me as well.
rvwaveren
Post by rvwaveren » 25 Jul 2018 09:44
Just replying to say this fixed it for me as well, thanks!
jogomes
Post by jogomes » 25 Jul 2018 10:51
Hi to all,
Updating to Clamav 0.100.1 did caused the issue.
Solution presented solved the issue.
JG
