how long does EFA keep the mail when the mail server is down.
Posted: 28 Jun 2018 16:15
by fodil1
My EFA server is connected with a MS Exchange 2013 server between a ipsec tunnel.The EFA server is an edge server.
Sometime,My internet connection goes down(Exchange side only) and i would like to know if the EFA server keeps all the mails and it will send them after the connection is restored?
Thank you,
Re: how long does EFA keep the mail when the mail server is down.
Posted: 29 Jun 2018 04:31
That behaviour is controlled entirely by postfix. See
http://www.postfix.org/postconf.5.html for a list of the configuration options.
Specifically, look for maximal_queue_lifetime and read up on that parameter.
By default, postfix will keep retrying message delivery for 5 days before giving up. Your configuration may be difference, so check your /etc/postfix/main.cf and see how it is configured for your system.
Posted: 03 Jul 2018 09:04
by Odon Garma
in my setup this setting in main.cf is untouched but very different from the default. it's set to 8h only, this could be rather short in some setups. U better double check this (u need to restart postfix after changing this setting)
Greetz
Posted: 03 Jul 2018 19:35
by fodil1
thank you for your help!
I changed the value from 6h to 5d in my postfix config.
it should be enough.
