Please be advised that I will reject assisting others with any issues that result from manually patching to 3.0.2.6. Not to be confused with yum update, that is okay.
An issue has been found manually updating MailScanner on eFa 3.0.2.6. You will end up with a broken system!
The great news is that we are moving much closer to a v4 release, so stay tuned!
[UPDATE]
clamav 0.100 crashes on eFa3 when yara rules are enabled in clamav-unofficial-sigs
https://github.com/extremeshok/clamav-u ... issues/203
To work around:
sudo service clamd stop
yararulesproject_enabled="no"
enable_yararules="no"
sudo rm /var/lib/clamav/*yar
sudo rm /var/lib/clamav/*yara
sudo service clamd start
