I've use an EFA as mail gw and behind one mail server.
In mail server i set up DKIM sign, key DNS are OK (ISPConfig 3).
If the mail was go through in EFA, DKIM was failed, but if i send it directly to destination, dkim was PASS.
I try enable / disable DKIM from menu no 17, but nothing changes...
I need to set something in shell in EFA to the DKIM (15+ domains) are arrived in pass?
Best regards
bdani
EFA 3.0.2.6 DKIM fail
Re: EFA 3.0.2.6 DKIM fail
Your ispconfig 3 server is DKIM signing the mail right?
And when you send DKIM signed mails from ISPConfig 3 through EFA DKIM fails, is this correct?
If so try disable ALL footers and other changes that EFA is doing on email, like "This message has been scanned for viruses and dangerous content"
Hi there,
EFA changes the message and ends up with dkim hash failure. Disabling EFA signatures works but it is not the best approach - we want EFA to tell users they are being protected
This issue Will be probably fixed on Efa 4.
How do you remove all footers in EFA? I have set signing non-spam to disabled and removed manually the webbug from MailScanner.conf, but the messages are still bouncing on DKIM.
