TLS error
Posted: 10 May 2018 22:19
by jamerson
Dear All,
after we did a EFA scan we figured out that the EFA does not send with TLS.
seconds test stage and result
[000.096] Connected to server
[000.188] <-- 220 filter.domain.com ESMTP Postfix
[000.189] We are allowed to connect
[000.189] --> EHLO www6.CheckTLS.com
[000.278] <-- 250-filter.domain.com
250-PIPELINING
250-SIZE 50240000
250-ETRN
250-STARTTLS
250-AUTH CRAM-MD5 LOGIN DIGEST-MD5 PLAIN
250-AUTH=CRAM-MD5 LOGIN DIGEST-MD5 PLAIN
250-ENHANCEDSTATUSCODES
250-8BITMIME
250 DSN
[000.281] We can use this server
[000.284] TLS is an option on this server
[000.285] --> MAIL FROM:<test@checktls.com>
[000.375] <-- 250 2.1.0 Ok
[000.375] Sender is OK
[000.375] It looks like we can send without TLS
[000.376] --> QUIT
[000.463] <-- 221 2.0.0 Bye
If the EFA does not send using TLS, is it a security issue ? can we configure this to send out using TLS ?
Re: TLS error
Posted: 11 May 2018 13:46
by budy
This is more of a Postfix configuration option. Usually, TLS - and STARTTLS for that matter is opportunistic, so postfix does offer TLS, but does not mandate it. You can setup Postfix to require TLS with specific domains and have it reject connections otherwiese. E.g., you could setup a mandantory TLS conenction by deploying a text file, where you enoumerate all domains, which Posftfix only is allowed to send/receive messages via a TLS connection like this:
## tls-policy
maydotls.com may
needdotls.com secure
needspecificmx.com secure match=server1.needspecificmx.com match=server2.needspecificmx.com
Configure this file in Postfix's SMTP settings:
smtp_tls_policy_maps = hash:/etc/postfix/tls_policy
Reload Postfix and only be able to use either TLS or TLS to specific MXs of the specific domain.
Re: TLS error
Posted: 11 May 2018 13:57
by jamerson
Thank you budy for your time.
if we dont configure the tls its not going to be a security issue ?
Thank you
Re: TLS error
Posted: 11 May 2018 14:04
by budy
This seems to be the wrong question. As I said… Postfix does TLS on an opportunistic approach. If both side agree on TLS, than it will be used. If the other end doesn't, than Postfix doesn't care and proceeds anyway. You can use the tls_policy to enforce TLS connections, where necessary. However, you can't force the other end into TLS, if it doesn't support that. In that case, you would cut-off any communications with that other domain. The tls_policy only assures, that no non-TLS connection can be made to any of the domains marked as being secure in the config file.
Re: TLS error
Posted: 19 May 2018 14:14
by jamerson
budy wrote: 11 May 2018 14:04
as i understand EFA send without TLS. and we can configure it to send using TLS,
it will use the TLS if the other side support that, and if not it won't use.
Re: TLS error
Posted: 20 May 2018 07:53
by budy
Well… it's always the receiving end, which advertises TLS capabilities or not. If the receiving end doesn't asvertise TLS in it's EHLO response, than postfix happily starts sending in plain text, since there is no other way to connect to the other end. If you, however, instruct postfix to only send to specific endpoint using TLS, it will not ever send messages in plain text.
Re: TLS error
Posted: 15 Jun 2018 19:43
by thewomble
If you have a need/requirement enforce TLS inbound from certain domains. This is an HOW TO:
create a file /etc/postfix/tls_server_policy_sender
sender-must-be-tls.com reject_plaintext_session
In main.cf add check_sender_access hash:/etc/postfix/tls_server_policy_sender, under smtpd_sender_restrictions
smtpd_sender_restrictions =
It forces the sending server to send TLS, if they cannot it will queue.
We have a requirement to send and receive certain emails using TLS, make sure the sending domain can use TLS before adding the domain to the file, if they cannot you will not receive the email. You have been warned.
Re: TLS error
Posted: 15 Jun 2018 23:30
by jamerson
thewomble wrote: 15 Jun 2018 19:43
Thank you for your answer.
this has been set up and working fine.
big thank you guys
