Recent Messages Blank
mcit
Post by mcit »
Hi Everyone
Since my upgrade to 3.0.2.6 I no longer have anything showing under recent messages. This is both for admin and user accounts.
I have checked the paths under /var/www/html/mailscanner/config.php
// Paths
define('MAILWATCH_HOME', '/var/www/html/mailscanner');
define('MS_CONFIG_DIR', '/etc/MailScanner/');
define('MS_SHARE_DIR', '/usr/share/MailScanner/'); // path for ConfigDefs.pl file
define('MS_LIB_DIR', '/usr/lib/MailScanner/');
define('IMAGES_DIR', '/images/'); // Leading and Trailing Slash Needed
//deprecated:define('CACHE_DIR', './images/cache/'); // JpGraph cache
define('TTF_DIR','./jpgraph/src/fonts/'); // JpGraph fonts
define('SA_DIR', '/usr/bin/');
define('SA_RULES_DIR', '/etc/mail/spamassassin');
define('SA_PREFS', MS_CONFIG_DIR.'spam.assassin.prefs.conf');
define('TEMP_DIR', '/tmp/');
Is there anything else that I can check to resolve this issue?
Matthew
Re: Recent Messages Blank
mcit
Post by mcit »
Thankyou. I saw that thread, however, I was not sure where to put that php file. Is there more info on what I need to do?
wget https://raw.githubusercontent.com/mailwatch/MailWatch/v1.2.7/upgrade.php
chmod +x upgrade.php
sudo ./upgrade.php
mcit
Post by mcit »
Thankyou. This is resolved now.
