Hi guys.
Using EFA.
- Is there a way to limit maximum outbound sending mail?
- What is Efa's currently default limit?
We recieve an error message when we wish to send messages to outlook.com and hotmail.com:
(host hotmail-com.olc.protection.outlook.com[104.47.32.33] said: 451 4.7.500 Server busy. Please try again later from [OUR-IP]. (AS3110) (in reply to RCPT TO command))
The mail server [OUR-IP] has exceeded the maximum number of connections
maximum outbound mail per domain in efa
Re: maximum outbound mail per domain in efa
Yes
On my outbound relay, I have mine restricted due to Verizon only wanting one connection at a time. Here's my settings:
/etc/postfix/main.cf
/etc/postfix/master.cf
default_destination_concurrency_limit = 20
initial_destination_concurrency = 5
# service type private unpriv chroot wakeup maxproc command + args
# (yes) (yes) (no) (never) (100)
smtp inet n - n - 1 smtpd
Thanks for the reply.
What that basically does if setting it to 1?
Can you make an example.
For example if we wish to send 100 messages to hotmail.com users with that setting, how will it do it?
with best regards
with best regards
Basically, that causes postfix to use a single daemon to send mail, which many mx's regard as more friendly, at the expense of loss of parallelism.bostjanc wrote: 03 May 2018 18:45 Thanks for the reply.
with best regards
If you want to send 100 messages at once, you would adjust default_destination_concurrency_limit = 100 to instruct the daemon to send that many over a single postfix session.
Thanks for the reply man!
So your suggestion would be to reconfigure that option to be more "polite"?
