Efficient use of Search Filters in MailWatch
maxkmv
Post by maxkmv »
Heeeellllloo Community!
Is there a comprehensive manual (or perhaps you can just point me in the right direction) on how to efficiently use MailWatch Filters. E.g. if I want to display all messages where one of the SPAM conditions have been met, i.e.
RCVD_IN_PSBL (Received via a relay in PSBL)
or those messages with URIBL_GREY or where BAYES was between 50 and 60%..
I tried to play with Search and Reports section and adding filters, but none seem to work for me as always getting 0 messages found. I know I am doing something wrong, but what? May be you can post an example or two - I am fast learner!
Thanks!!
Re: Efficient use of Search Filters in MailWatch
1/ Spam Report contains RCVD_IN_PSBL
2/ Spam Report contains URIBL_GREY
3/ Spam Report contains BAYES_50
(bayes = 40-60% - not 50-60%)
I think you can see where I am going with this. Give it a try and see if you get more than 0 messages found.
maxkmv
Post by maxkmv »
YEESS!!! :clap: :dance:
Thank you! Thank you!
